Wet Rear Floor : HELP
Old 06-09-13 | 06:08 PM
Chaos236's Avatar
Chaos236
Default Wet Rear Floor : HELP
06 GS 300 AWD wit soaked rear floor. Pulled seats and rotating dry towels under the carpet and pad.
Did a search and have been down there looking all over. Used mirror and went over tranny...
Can't find the plug too remove or the cover to take off.
I did get the 11" bent pliers...help.
Thanks.
Old 06-09-13 | 06:40 PM
burny's Avatar
burny
Wet Rear Floor : HELP-dsc00262a.jpg Pull this boy out this week like a rotten tooth. Read the thread on this and there is a write up on how to see it.
https://www.clublexus.com/forums/gs-...-ac-drain.html
Old 06-10-13 | 12:13 AM
LexToy3's Avatar
LexToy3
CL Folding 25,000
I took my carpet out of the car to let it dry. It seemed to have been leaking for a bit before I noticed it. Was able to get it cleaned after a few good cleanings.
Old 06-10-13 | 06:19 AM
Chaos236's Avatar
Chaos236
I read the write us, have a fan blowing on the raised carpet now.
More detail as to where the plug is?
Thank you
Attached Thumbnails Wet Rear Floor : HELP-gs1.gif   Wet Rear Floor : HELP-gs.gif   Wet Rear Floor : HELP-gs2.gif
Old 06-10-13 | 10:44 AM
TWong350's Avatar
TWong350
CL Folding 10,000
Yuck...did you find the root cause? Where's the water coming from? Likely HVAC drain.
Old 06-10-13 | 11:17 AM
Chaos236's Avatar
Chaos236
I have the car on the lift, sitting under it looking up at the trans (awd) what now...
Old 06-10-13 | 04:47 PM
Chaos236's Avatar
Chaos236
Done.
The Camera was a must, first whack at it and down came the water.
Called the dealer.
1. Bring it in.
2. Run a diagnostic with tech and factor in mileage, vin ect...
3. Check on TSB's after they have car.
4.Give estimate and schedule repair date.
Thanks everyone....! Yea
Old 07-11-13 | 05:49 AM
burny's Avatar
burny
to the top for the guy inquiring about this
Old 07-12-13 | 09:07 AM
mydawgz's Avatar
mydawgz
They know of this issue at the dealer. It took a long time and it took some work but they fixed it at no cost)
Old 07-12-13 | 09:12 AM
3GS404's Avatar
3GS404
Seriously.. Dealer fixed at No Cost ? I think im gonna bring my car in today for them to inspected
Old 07-13-13 | 05:33 PM
Chaos236's Avatar
Chaos236
I jabbed mine with the bent tipped pliers. Poked a hole on the rubber grommet and the water poured out!
Ants350
01-03-19 03:41 PM
ericsan13
RX - 4th Gen (2016-2022)
28
01-14-18 10:36 PM
kmchuk
GX - 1st Gen (2003-2009)
09-12-17 11:39 AM
Lex Luga
54
03-10-16 11:07 AM
jujulo700r
04-21-08 11:02 AM
