Help!! Need wheel advice asap!!
3GS .... that is a pretty aggressive setup, but i have seen it done before.
What year is your GS?
Keep in mind all of this also depend's how low your going also these specs are based on using camber to your advantage so i would recommend a camber kit. Another main issue to keep in mind is you are AWD so you would need to keep your tire diameter the same.
Now the 19x11 +15 Front has been done. You wouldnt need a spacer but you would need fender work done ( fender rolling, pulling and possibly flaring). and for tire sizes you would be around a 235/35/19.
for the rear as a 19x11 +22 offset you would once again need to do some fender work ( rolling/pulling). and depending how low you go again you would need to stretch your tires close to a 275/20/19. The rear is more capable of having a wider wheel setup so hence why you would not have as much tire stretch and or fender rolling based on the capability to camber your wheels.
It will be a awesome setup if you do it!!!!
What style of wheels are you looking into ?
