Question about steering wheel volume button problem
Old 07-02-13 | 07:42 PM
LADavidGS's Avatar
LADavidGS
Default Question about steering wheel volume button problem
i have 06 gs300 and my volume button on the steering wheel is loose. Any advice? Do I need to replace it or can I fix it?
Old 07-02-13 | 08:37 PM
MX5's Avatar
MX5
Mine's a little loose but if you just push it down flat it stays in the right position. Out of habit I use the steering wheel buttons for track selection and the console **** for volume. At least in the GS the **** is not a far reach
Old 07-03-13 | 01:05 AM
XxGoKoUxX's Avatar
XxGoKoUxX
Only way to know is disassemble the piece and look inside on what is broken. USUALLY it is just the rubber and it is not replacable with another rubber insert, so yeah, I would look for a replacement if it bothers you.
Old 07-03-13 | 09:36 AM
LADavidGS's Avatar
LADavidGS
Anyone have pdf or instructions how to disassemble the volume button?
Old 07-03-13 | 11:09 AM
GS350Lexus's Avatar
GS350Lexus
Need to remove the airbag to get to it.
Old 07-03-13 | 02:59 PM
XxGoKoUxX's Avatar
XxGoKoUxX
Ouch, you're kidding right?:
Old 07-03-13 | 05:20 PM
GS350Lexus's Avatar
GS350Lexus
Nope i did a ton of research because i wanted to replace those dim bulbs and airbag needs removal.
Old 07-03-13 | 06:27 PM
LADavidGS's Avatar
LADavidGS
Damn it. So another expense down the drain.
doodoo
02-25-24 04:34 AM
MOBARISTO
02-09-15 04:51 AM
bklynjoker
07-15-13 08:24 PM
