Water on carpet possible clogged A/C line???
I have an 06 GS 300 and discovered excesive water on the driver side rear carpet and passenger front carpet. The rear looks as if the moisture came from the vent under the seat. Has anyone had this issue and how can I remedy the problem?
there are threads all over the place on it. There is an A/C drain plug that is up under the car where the bell housing meets the fire wall. It needs to be pulled out and thrown away. Do some searching on here and you will find a few threads detailing the process. I just did it a month ago.
romeo291
SC- 1st Gen (1992-2000)
10-01-08 09:45 PM
