gs350 Water Pump Replacement
Old 07-11-13, 04:46 PM
BGG
BGG's Avatar
Default gs350 Water Pump Replacement
Hey Guys, my 07 has about 62.5 on it and im wondering if I should replace the water pump. I have noticed any drop in coolant levels etc, but I am one who tries to be very preventative when it comes to maintenance. Any thoughts? Thinking about buying the kit and tackling it next weekend.
Old 07-11-13, 05:28 PM
burny
burny's Avatar
My wife's 07 is at 82k and I will probably replace it this year once it cools off some. No fluid loss at this time.
Old 07-12-13, 01:05 AM
ibidu1
ibidu1's Avatar
Theres a thread I created about water pumps, personally I would replace it for peace of mind. You can buy them very cheap and there easy to install. Aisin is an aftermarket brand owned by toyota, basically youll get an OE part for the cost of aftermarket. Youll see toyota stamp shaved off
http://www.ebay.com/itm/Aisin-WPT-137-Engine-Water-Pump-/251295078883?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AGS350&hash=item3a825a99e3&vxp=mtr
Old 07-12-13, 06:22 AM
pelphrey
pelphrey's Avatar
I am in the same boat. Last weekend the dealer said that the water pump was going bad. Its a 2007 with 62,xxx miles as well.
The car doesn't get driven a lot. So I'm going to do what burny is doing and replace it this fall when it gets cooler outside.
Old 07-12-13, 06:02 PM
ibidu1
ibidu1's Avatar
If they said it is bad, I would replace ASAP. You can destroy your engine!
Old 07-13-13, 03:16 PM
alchemist
alchemist's Avatar
Just bought all parts off ebay. I plan to tackle next weekend as preventative maintenance. My car has 90k. I will flush coolant while I'm at it.
Old 07-13-13, 03:50 PM
burny
burny's Avatar
LOL, you aint got no choice on the coolant bro. Replace your upper and lower hoses and the serpentine belt while you are at it.
Old 11-06-13, 05:59 AM
burny
burny's Avatar
Do you have to remove an A/C hose or not?
Old 11-06-13, 07:10 AM
alchemist
alchemist's Avatar
Will I lose coolant while doing the water pump replacement? Of course.
But actually, I technically do have a choice. I don't consider it a flush if I don't remove coolant from the radiator and remove the engine block coolant drain plugs.
Old 11-06-13, 11:55 AM
burny
burny's Avatar
yo Richard, you didn't answer my question about evacuating that a/c and getting the high pressure line out of the way? Is that necessary?
Old 11-06-13, 03:44 PM
ibidu1
ibidu1's Avatar
When I did mine I never opened any ac lines. This job looks harder then what it really easy. Just a bit time consuming less then 2hrs for me.
As far as cooling you do not have to remove all the coolant, just drain half the radiator into a clean container to allow you to take off the top radiator hose.
Just make sure to use blue loctite on the water pump and pulley.
Old 11-06-13, 04:04 PM
burny
burny's Avatar
thanks brother. Doing the recall this coming Tuesday and will do water pump after that. Got everything needed here and will replace hoses, belt, thermostat, idler and pump. Will flush radiator at this time also.
Old 11-07-13, 07:48 AM
wickedtaco
wickedtaco's Avatar
When installing a H20 pump, shouldn't the timing belt be changed out as well?
If taken to the dealership does anyone know how much they will charge for this service?
cheers
Old 11-07-13, 09:22 AM
burny
burny's Avatar
3rd generation has chains.
alchemist
alchemist's Avatar
cheers
If you have the 350 motor, you have a chain not a belt so not necessary to change
Quick Reply: gs350 Water Pump Replacement
