Torque Lbs. Specs for tensioner and idler pulley - Service Manual Help
Anyone with a service manual, I need your help getting the correct Torque Ft. Lbs. specs for the single bolt that holds the tensioner pulley and idler pulley.
Thanks in advance for your help
Thanks for your input. If anyone else has a service manual and is able to advise on the factory recommended torque specs, please post. Thank you all.
