Bluetooth: Audio Muting on Outgoing Calls??
Hi all,
The one thing that irritates me about the handsfree phone system in my GS430 is that if I am playing audio while placing an outbound call, the music won't be muted until the call is actually connected. I'll suddenly go from listening to the news, to hearing someone on the other end saying "hello?!" or someone's voicemail greeting underway,
Is there anyway to change the setup so that I can hear the outbound call in its entirety? Call me old fashioned but I want to hear the phone ring and the call connect!
Thanks for your help. I searched the Board and the owner's manual without luck.
VL
VL
There isn't, I believe that is your phone. Mine's rings like it should until someone picks up.
What phone do you use? Is it BB, Android, or iOS? (I'm currently using Android OS, it's been the same between gingerbread, ICS, and JB).
Hi - I'm using the OEM Bluetooth connection with an iPhone 5...
Waiting for iSimple to arrive so I can stream audio, maybe that will put this issue to bed at the same time.
I hate to burst your bubble (not that I'm trying to) but our cars do not come with Bluetooth audio streaming. I also have a hunch (not 100% sure as I haven't tried on the GS, but on another vehicle) you'll only get one speaker to work I believe.... Also, it will sound like garbage if you plan on audio streaming to your HU.
Best solution would be a vaistech unit (ipod/iphone compatible) or buy the 3.5mm jack to tape deck converter...
IMO, the BEST BEST BEST audio resolution came SURPRISINGLY from the tape deck to 3.5mm converter.
GL OP!
GL OP!
http://www.autotoys.com/x/product.php?productid=25737
I'm soo sorry about that post, it was my fault as I should have looked into it further than just blabbing out of my behind. That's a unit, similar to Vaistech, Grom, and Prestigious Society.
It's out now I believe because in another thread, someone has posted about it (although I think it's the non-BT version).
I'm definitely considering this kit now, as it's got a USB connection for phone/ipod/USB stick, and it's only 150!!!
I think I paid a bit more for my Vaistech unit, and it doesn't have as many functions as the iSimple! Thanks for the insight!
P.S. One thing though.... does this come with video feed? It'd be pretty dope if I can feed video through it and play music videos/movies on longer drives.
I have the GS430 too, and I believe it has to do on HOW you place your call......
If I remember correctly, if you dial via your phone, you won't hear anything until the call actually connects. I think I have experienced that. Given that most people had problems importing the phonebook into the Gen4 Nav, leads me to believe that you are probably dialing via the phone, correct?
If you dial using the HU switchboard, then mine mutes as soon as I press the call button. Likewise, when receiving a call, mine mutes the music. Does that work for you too?
And I use the BT35 without microphone for my Audio streaming. Sounds good, but will need to increase the volume. I was using the cassette adapter too, but the BT streaming is much more convenient. Overall I am quite happy with it. Without the BT microphone connected, with my Android, my calls will still go through the car speaker and microphone, while my media plays via the BT unit connected to the radio. And they all integrate, i.e. my music still mutes audio when call comes in and connects to phone BT during calls, then switches back to Media.....
If you don't have nav, you're in the clear, otherwise you need a unit to enable and disable the brake lock hack for the car.
On my non-nav car, I cut the pink wire and believe I grounded one side for it to work. This allowed me to make phone calls and still be on the road at the same time.
This is probably a bad idea to do this, I would only do it on a clear road and VERY low speeds.
eugenez
NX - 1st Gen (2015-2021)
05-27-16 09:11 PM
albino1
09-16-13 10:59 PM
