One Daytime Running Light Not Working ??
Changed out my right DRL bulb as it was only working during high beam use. With the new Sylvania 9005 bulb installed I get the same result. Bulb only works as high beam and not as DRL. The left works fine as DRL and High beam but the right works only as high beam. I cannot find a blown fuse and don't know where else to look.
Any suggestions on what may be causing this issue?
There are 3 sets of fuses I believe on our GS. The front one driver side (I believe) the one in the passenger side under glovebox, and the one in the rear trunk, on the driver side. Check all 3 to make sure?
SiulMan19
01-12-16 04:19 PM
