Headlight Question
Old 11-04-13, 02:03 PM
tpjc1018
tpjc1018's Avatar
Default Headlight Question
My driver's side bulb at times will just go completely off. Is it the bulb or the ballast shooting craps?
Old 11-04-13, 02:56 PM
burny
burny's Avatar
there are a ton of threads on this. Swap bulbs and then you will know. My guess is the bub is fixin to blow
Old 11-04-13, 08:32 PM
XxGoKoUxX
XxGoKoUxX's Avatar
^What above poster said...... New people really should hit up the DIY threads, or do a search from now on
Old 11-05-13, 02:53 AM
IXI187IXI
IXI187IXI's Avatar
yes this is a topic that comes up at least once a week. do what post #2 says and swap the bulbs from side to side. if the problem follows the bulb, then its more than likely a bad bulb.
Old 11-07-13, 03:55 PM
tpjc1018
tpjc1018's Avatar
I swapped the bulbs & I get a flicker 10 & then it goes shot.
Old 11-08-13, 02:19 AM
IXI187IXI
IXI187IXI's Avatar
a flicker from the same bulb? ie it didnt work on the drivers side and when you swapped it over to the passenger side it flickered? if so then more than likely your bulbs are going and its time for new ones.
Old 11-08-13, 11:37 PM
XxGoKoUxX
XxGoKoUxX's Avatar
If the bulbs are out, check out our vendor XenonDepot, great bulbs from what I've heard (once again, repeated many times too! LOL)
GL OP.
Old 11-11-13, 02:33 PM
tpjc1018
tpjc1018's Avatar
Turns out the flicker was from me not having the bulb secured tight enough to the latch. Took it to the dealer after I realized this. They believe the ECU is going bad. They say the entire assembly has to be replaced. $1600! Haven't got it back yet. Glad the car is still under Certification.
starstreak
10-03-18 01:45 AM
hahahaf
IS F (2008-2014)
04-29-16 02:58 PM
JEFFOS69
05-05-14 05:40 AM
Mrd916
IS F (2008-2014)
01-19-13 08:12 AM
Quick Reply: Headlight Question
