VSC error after changing headlight bulbs
I have a 2007 GS 430, 126,000 miles. Initially I had one faulty headlight that would not work but after turning the switch off/on, it would work again. Eventually both headlights started malfunctioning. After reading other forums, we elected to change the headlight bulbs. So far that has worked. However, after changing the bulbs, the VSC (Vehicle Stability Control) and check engine lights came on. After running the headlights and using the car to go to/from work with about 4 stops and restarts, the car reset itself and the warning lights turned off. Scared me at first because I had also just had suspension work done. However, the Headlamp Level Control System is part of the VSC system, which makes sense, just wasn't prepared for the warning lights.
user 528962307
08-21-15 08:19 PM
