The best tip/trick/diy/diagnostic tool ever
Old 03-08-14, 10:05 AM
  #76
40069911
40069911's Avatar
Was hoping for some help. I been having tranny problems so I got this tool to do a little diagnosis.
https://s3.amazonaws.com/sonnax-dev/...61E-ZIP-IN.pdf
Page 3 Figure 11 shows the outline of how our transmission works. Pictured are A761E but our A960's are identical working manner.
Two weeks ago I recorded using the Tech Stream while driving for about 2 miles. This morning I looked at my data and it showed that the SLU and Lockup Solenoid don't turn on till 5th gear for both. The chart from Sonnax shows the SLU should turn on and stay on from 2nd to 6th gears.
I have a p0761 error that keeps turning on because there is a delay of my 3-4 shift. I manually shift so this error code isn't tripped but there is a 2 second delay and harsh 3-4th.
Can someone that recorded see if their SLU turns on and when. Thanks in advance.
Old 03-08-14, 01:30 PM
  #77
SoFlaGS350
SoFlaGS350's Avatar
Where is the OBD-II connector?
Old 03-08-14, 10:41 PM
  #78
40069911
40069911's Avatar
Under the driver side dash. It's aligned with steering wheel. It has a cap that needs to be opened.
Old 03-09-14, 09:30 PM
  #79
Kuleaze
Kuleaze's Avatar
Just ordered one and liked your review Chris!! Thanks for the info...
Old 03-10-14, 07:43 AM
  #80
Marklouis
Marklouis's Avatar
Just ordered mine today. Cant wait to turn of my DRL.
Old 03-27-14, 07:35 PM
  #81
adtrance
adtrance's Avatar
Originally Posted by mr. tetsuo
arrived in the mail recently and installed without issue. but when trying to connect to my car, got this error message. tried everything to make it work (except uninstall then reinstall). any help?
Anyone else getting this? I'm getting this same error message as well.
Old 03-28-14, 09:52 AM
  #82
lesz
lesz's Avatar
Received 1,014 Likes on 693 Posts
Does anyone know, if you disable the daytime running lights with Techstream, does that keep them off completely regardless of which light position is selected on the stalk, or does it just shut them off when the stalk position is "off" but still leaves the DRL on when the stalk is set to "auto"?
Old 04-04-14, 08:24 PM
  #83
Marklouis
Marklouis's Avatar
Received mine and downloaded to my Windows 7, will try it out this weekend. It's version 8.3. I did run it in xp sp2 compatibility mode. It also had the mini VCI driver with .pdf manuals
Old 04-06-14, 06:18 AM
  #84
Kuleaze
Kuleaze's Avatar
Yes, I'm getting this error as well. Haven't figured out what the issue is yet...
Old 04-06-14, 10:58 PM
  #85
Synergy001
Synergy001's Avatar
Just ordered mine. Can't wait to try it out...
Old 04-07-14, 07:54 PM
  #86
Marklouis
Marklouis's Avatar
Also received this error message at first, but after starting the vehicle and letting the drivers completely load for the USB cable, (which drivers are included on the disc) it connected successfully. It just took a minute or so.
Still playing with the settings and customizations, however the health check seems very accurate for I already knew what my problem areas were, the telescoping wheel being one of them.
And yes, I turned off the annoying DRL's
Also, I did not have to leave the car running for customizing, just left the ignition on. You need to have the car running to run the healthcheck on the system.
Old 04-12-14, 10:47 PM
  #87
Schmexus
Schmexus's Avatar
Anybody tried Carista yet? I attempted it only to find out my Nextbook doesn't have bluetooth capability. I really thought that was a standard item even on el cheapo tablets.
Old 04-13-14, 03:19 PM
  #88
49erGS460
49erGS460's Avatar
I did and it doesn't work.. Not supported and confirmed from the dev.
Old 04-16-14, 08:10 AM
  #89
Carista
Former Sponsor
Carista's Avatar
Correct, as of now we don't support the 3rd gen GS because it uses Toyota's older communication protocol (btw, the Yaris uses the newer one since 2006... but the higher-end models don't. Go figure). We are looking into adding support for that older protocol though, and so far it seems possible with an ELM327 Bluetooth device. I'll let you guys know if we succeed.
Old 05-02-14, 07:31 PM
  #90
mr. tetsuo
mr. tetsuo's Avatar
I fixed this by running xhorse in the background. Made sure it said connected before trying to connect to my car.
Also on sonar mode, does anyone know the difference between normal and steering? Was afraid to change it lol
Quick Reply: The best tip/trick/diy/diagnostic tool ever
