Jerk/jolt/clunk when coming to a stop
#32
I spoke to ta1972 and he had the same problem I was having which is a hard clunk when coming to a stop as the car get below 10mph now if you are having this same problem and having hard shifting then the problem is not your transmission its your main ECU. Like you I too went to Lexus for them to check the car out and the told me my transmission need to be replace...so I got a used one and ended up with the same problem and was getting frustrated. I ended up talking to Ta1972 and replacing the ECU and now my car drives like its brand new.
#33
If lexus told you to replace and still the same, then you should complain to them for misdiagnose first.
They have to take responsibility for that. If they can't help you, then you would need to find out your ecu part number. You would have to get the exact part number to marry it to the car.
Pm me if you need some advice.
Did you say you replaced the ECU and it fixed the problem. I have a 2006 Lexus gs300 .
#34
#35
No Lexus was very adamant that the transmission was the problem and wanted me to replace it. So I ending buying the ECU from them with my shop discount it's about $1200 without it it $1550 ...and it solve my problem.
#36
Did your shop reprogram the ECU for you as well ?
#37
My 2006 gs300 jerks as well when coming to a stop,usually a soft one then a hard jerk. I took it to the shop today they think its the transmission but it shifts and drives fine only when stopping. Any thoughts anyone?
#38
The Ecu runs about 1400-1500 , and a 130.00 for installation.
#39
Taking car to the dealer tomorrow, unplugged the battery, unplugged the ecu 10amp fuse no change. Ill keep you guys posted on what the outcome is. Still a soft jerk then a hard one when stopping.
#41
I have same issue
[QUOTE=ta1972;8953001]It's finally fixed!!! I'm super happy!!! It was the fricken ecu all this time!!! Lexus should make this a recall!!![/QUOTE
Can you explain the process of getting it fixed? Did you just swap ecu and it worked? How fif younfind out it was the ecu?
#42
06 gs300 kicking transmission when downshifting
Hi i just got a 06 gs300 and i have a very bad downshift i feel 2 kicks on 2nd and than on 1st when it come to stop
I checked for code nothing was found . Do you have any ideas on that please let me know
209-495-9333 thank you
I dont want to keep buying parts and putting them on
#43
The Ecu is about 1400, and the installation is about 130.00 including programming.
#44
2006 Lexus gs430 jerks hard when coming to a stop
I took My 2006 lexus GS430 Lexus of Greenville In Greenville sc Had a harsh jerk when coming to a stop. I took it to lexus and the said it was the transmission. I hold the service advisor that i was reading a post, from lexus forum that the ECU was the cause. He came back an hour later and said the TEC said it was the transmission. I was sceptical. He said it will cost around 5000 to fix it. My mind was saying the are taking advantage of me. Well i let them do the work. (GUESS WHAT NEXT AFTER THEY PUT A 5000 TRANSMISSION IN IT) They came back and said it need a (ECU) I told them that i said that before you cost me 5000 for nothing. Needless to say it was another 1700 for the ECU. It ended up costing 6,700 for the total fix.
If you have the same problem with the transmission, has a harsh jerk shifting when you come to a stop, DO NOT LET LEXUS TELL YOU IT THE TRANSMISSION, DO THE ECU FIRST.They will tell you anything to get to sell you the repair work.
feel free to to ask me any questions.
#45
