Jerk/jolt/clunk when coming to a stop
Old 12-11-13, 12:03 PM
gsciacco
gsciacco's Avatar
Default Jerk/jolt/clunk when coming to a stop
Hello everyone! First off, I'm new to the forums and have already benefited quite a bit from reading through all the GS threads. Thanks to all the members of the forum for your feedback, advise, etc.
I am the new owner of a 2007 Lexus GS350 and I absolutely love the car. 70k miles and it has been well taken care of by the previous two owners. The question I have is regarding a strange subtle jerk when coming to a stop. This seems to be the most intense with a medium force stop but I can also feel it when coasting to a stop. It happens frequently and sometimes is less harsh than other times. I noticed it right after picking up the vehicle but I didn't really pay much attention. After driving the car for 2 months I notice it more. The jerk seems to be happening during downshifting and is at about 15 mph every time. It's not extreme but passengers typically notice it if I point it out. Then they can feel it every time it happens. The other shifts are smooth including accelerating and so forth.
I've read a few threads that mention it could be a normal downshift feature of the vehicle. I'm taking the car into the shop (not the stealership) to have the problem looked at in the next few days. I wanted to post to not only get feedback here but to also post a followup on what the shop comes up with. If it's a normal characteristic of the car then I'm ok with that. But I'm concerned there is a bigger issue.
I reset the ECU (pulled the ETC and EFI2 Fuses) about two weeks ago but haven't noticed a difference in shifting.
Any input would be greatly appreciated.
Last edited by gsciacco; 12-12-13 at 07:56 AM. Reason: Discovered last night it happens when coasting
gsciacco is offline
Old 12-11-13, 12:20 PM
elexusparts
Former Sponsor
elexusparts's Avatar
The World Standard fluid transmissions have no dipstick so it is possible that it was serviced and it is overfull. I would check the fluid level first because an overfilled trans. can cause harsh shifting.
I checked and found no TSB's for harsh shift.
elexusparts is offline
Old 12-11-13, 10:52 PM
XxGoKoUxX
XxGoKoUxX's Avatar
THAT in particular is not normal, you were probably reading a local thread on someone hitting the "S" shift function. That is normal, as the downshift it gives him a slight jerk... no jerkiness. When you say downshift, are the brakes applied? It sounds like your brakes are in the equation and I would start diagnosis there.
Either way GL and keep us followed up OP!
XxGoKoUxX is offline
Old 12-12-13, 08:03 AM
gsciacco
gsciacco's Avatar
Thanks, I'll definitely have that checked out if I can't get to it before I take it to the shop on Monday.
I tried to find the thread I was referring to but no luck. I should have mentioned a few things. The jerk happens when I'm applying the brakes and can also be felt when simply coasting to a stop and not applying the brakes. I updated my post because last night I coasted to a stop without any brakes applied and I felt the jerk. It almost feels like a downshift but the car sort of lunges forward. Not a violent lunge but it's not something I've felt in other cars.
Anyway, thanks for the info and I'll keep everyone updated on the outcome next week when it goes to the shop.
gsciacco is offline
Old 12-12-13, 08:26 AM
BGG
BGG's Avatar
Do our cars have engine and transmission mounts that need to be replaced over time?
BGG is offline
Old 12-12-13, 08:38 AM
alchemist
alchemist's Avatar
I personally have not heard of this being an issue in the GS but I could be mistaken.
alchemist is offline
Old 03-10-14, 03:09 PM
Yamir
Yamir's Avatar
Hey, did you ever find what was causing the downshift jerk?
Yamir is offline
Old 03-11-14, 07:50 AM
ibidu1
ibidu1's Avatar
I would do an induction cleaning and replace the plugs, and clean the throttle body. Could be carbon build up on the plugs, giving you a slight miss fire or hesitation
ibidu1 is offline
Old 03-11-14, 10:22 AM
BinaryJay
BinaryJay's Avatar
Are you sure it might just not be a suspension component? If a suspension linkage is broken like rusted through, you could hear similar things.
BinaryJay is offline
Old 02-05-15, 05:24 PM
crapoud
crapoud's Avatar
Default same issue....
So I get a jerk when coming to a stop. Took it to lexus and the did the recall and got pistons etc but problem still there. Then they tell me its the transmission (code shift solenoid B performace). I then take it else where to do a transmission swap but still have the same problem! Do I need to get the new transmission coded? What am I missing here?
Please help! any info will do. Thanks 2006 is250 rwd
crapoud is offline
Old 02-05-15, 08:44 PM
GS350Lexus
GS350Lexus's Avatar
Does it happen only when cold? I notice that when the car is cold I get some ruff downshifts, but after normal operating temperature everything is fine ( until i do some hard braking and I am in the power mode) Power mode does some hard downshifts, might want to keep it in normal. Also for sake of just trying, put it in snow mode see if you still notice same symptoms.
GS350Lexus is offline
Old 02-05-15, 09:16 PM
LoveThatV8
LoveThatV8's Avatar
I'm on Sport shift most of the time in LA traffic and I get what you mean when the jerking happens from downshift from 2nd to 1st. As I get to learn the sweet spots on downshifting... I shift from 2nd to 1st around 2000rpm-1500rpm for that engine braking feel. I get that unexpected jerk if i downshift from 1000rpm and under. Hope that puts info on unexpected jerking cause it feels like i shat in my pants when that happens.
LoveThatV8 is offline
Old 02-06-15, 02:07 PM
debeatup
debeatup's Avatar
I have literally the EXACT same issue as the original poster. Right at 8 mph during deceleration, whether braking or even an idle roll, I get what feels llike a rough stall/jerk. I know it's not suspension or brake related and it only happens when stopping, never in acceleration.
Thanks in advance for any help you guys may provide
debeatup is offline
Old 02-11-15, 04:14 PM
AlvinGS300
AlvinGS300's Avatar
Default Same problem here!!!
Just a voilent jerk when coming to a stop ...any ideas of what it could be?
AlvinGS300 is offline
Old 02-11-15, 05:25 PM
Tantrix
Tantrix's Avatar
Sounds like the engine mounts, my old acura legend had the same problem till I changed out the mounts....it could be something else.
Tantrix is offline
Quick Reply: Jerk/jolt/clunk when coming to a stop
