Vossen Wheels for 2006 GS 430
Old 12-18-13, 12:30 PM
chadchad
chadchad's Avatar
Default Vossen Wheels for 2006 GS 430
Want to know if I can go with the Vossen VVS-CV3 wheels with out lowering my car and not doing any modifications. Front 20x9 38 offset tire size 245/30/20 Rear 20x10 45 offset tire size 275/30/20
Old 12-18-13, 01:46 PM
Skylar978
Skylar978's Avatar
Is there a specific reason you want a square setup all around? I would do 20x9's out front, but since you do not plan to lower your car, you may be fine running that setup..
Old 12-18-13, 02:57 PM
Roe
Roe's Avatar
It'll look like a GS with a lift-kit on it.
Old 12-18-13, 08:58 PM
masboy
masboy's Avatar
so same wheel width but rear with thicker tires? why? :/
Old 12-18-13, 09:00 PM
XxGoKoUxX
XxGoKoUxX's Avatar
He hasn't posted offset of the vossens yet, so you can't answer if he will be fine or not with that setup.
OP, you need to post offsets with those specs, so that the wheel guru's will know if you'll be okay with it or not.
GL!
Heh.... I've seen a GS on 20s.. you make it sound like he can go mudding with the car with aftermarket wheels :P
Old 12-18-13, 10:13 PM
masboy
masboy's Avatar
Old 12-19-13, 03:42 AM
IXI187IXI
IXI187IXI's Avatar
thats what i was thinking
not to mention your 245/35 will rub on full turns as the tire is too big
rimini
Suspension
04-08-19 11:59 AM
DallasGSF
GS F (2016-present)
06-18-18 04:53 PM
Pilotpri
05-20-14 02:18 PM
bwk
07-30-13 07:16 AM
CSHFLW
Wheels, Tires & Brakes Forum
07-01-02 04:19 PM
Quick Reply: Vossen Wheels for 2006 GS 430
