Invidia midpipe installed- GS350
Old 01-11-14, 10:56 PM
designo
designo's Avatar
Old 01-12-14, 12:42 AM
Schmexus
Schmexus's Avatar
^^^ mine sounds nothing like that.
Old 01-12-14, 01:08 PM
XxGoKoUxX
XxGoKoUxX's Avatar
ty for the seller's name schmexus, now i'm contemplating whether or not I should pick it up since it's dirt cheap
Old 01-12-14, 01:14 PM
xmike714x
xmike714x's Avatar
Originally Posted by Schmexus
I wasn't looking for a loud exhaust, but I wanted a deeper tone. I'm pretty happy with the invidia midpipe. It sounds classy without being obnoxious. There is absolutely zero drone in the cabin. You can hardly notice anything has changed from the inside. I'm using the stock axleback.
The $11 o2 socket is a must for the install due to the shield around them.
My only complaint is there is a pinhole in one of the welds that's causing a tick noise. The welds are beautiful so I'm sure fixing it with a tack weld is going to look hideous, but it's no big deal.
any warning codes or check engine codes pop up?
Old 01-12-14, 02:30 PM
Schmexus
Schmexus's Avatar
I've only driven a couple hundred miles, but I haven't had any troubles yet.
Old 01-15-14, 09:44 AM
3gs350awd
3gs350awd's Avatar
Does this delete the cat
Old 01-15-14, 10:49 AM
Schmexus
Schmexus's Avatar
It deleted 2 cats after the secondary o2 sensors. This might not pass inspection in some areas.
Old 01-15-14, 11:16 AM
Skylar978
Skylar978's Avatar
Although this isnt a GS, I did find a video on a is350 as I was also interested in this mod. I think I will have custom made pipes instead that will look similar to the invidia..
it will more or less sound exactly like that since we(gs350) obviously share the same motor as the is350.
Old 01-15-14, 11:17 AM
Skylar978
Skylar978's Avatar
Another video, but an awkward angle. At least there is some sound though..
Old 01-15-14, 11:21 AM
Skylar978
Skylar978's Avatar
Another vid of a straight piped (Tanabe) mid pipe..
Old 01-15-14, 11:22 AM
Skylar978
Skylar978's Avatar
Megan midpipe with stock muffler..
Old 01-25-14, 11:38 AM
Schmexus
Schmexus's Avatar
Finally got the CEL. Any way around this issue or do I just clear it every so many hundred miles?
Old 01-26-14, 06:24 PM
Broken2G
Broken2G's Avatar
I have heard o2 sensor extensions can help.
Old 03-13-14, 04:21 PM
gearhead24
gearhead24's Avatar
Default Schmexus, AWD or RWD?
Was your car an AWD or RWD?
Also, was the CEL due to the midpipe and missing cats or something else?
Thanks.
Old 03-13-14, 05:24 PM
Schmexus
Schmexus's Avatar
It's RWD. I tried the normal straight o2 extensions and I still got the cel every other day. I've had the 90 degree extensions on for about a week now with no cel. Hopefully that does the trick.
I don't see why I'm even getting a cel considering the only thing that changed in front of the rear o2's is a slightly larger diameter pipe. The rear cats that were deleted are after the o2. Unless the higher flow is what was causing it?
Quick Reply: Invidia midpipe installed- GS350
