Can you visually inspect water pump for leakage?
Hey guys. 06 GS 430, 80k miles, still under CPO warranty for another 15 months or 20k, whichever comes first. I know the water pump is prone to leaking as the car gets up in age and I was wondering if there was a way for a non-tech person like myself to visually inspect it to look for leakage.
I should probably add that I don't know where the water pump is or what it looks like. Thanks for any help.
e
e
Yes. Look for a DIY thread on here, the guy was replacing his water pump. He had many pictures and I think he also show his old one have sign of leak.
I replaced my water pump at 100k miles. It didn't leak but was replacing the timing belt at the same time. Easier to do both. Might be cheaper on the labor side too since they kinda link.
I'm thinking that if the water pump is leaking, it will be replaced under the CPO warranty and maybe I can get them to do the timing belt at the same time.
e
e
I wrote a DIY for the 350 motor:
https://www.clublexus.com/forums/gs-...with-pics.html
When I was underneath changing my oil filter I could see the leaking coolant behind the pulley.
I'm actually wishing it were leaking because (a) I'm still under CPO warranty and would love to have it replaced under warranty, and (b) I'm coming up on my timing belt service and if my water pump needs to be replaced anyway, maybe some of the timing belt service labor could get absorbed by the warranty.
LOL..... I gotcha there brother.... as an FYI: I got my service completed, all for $900. Parts & labor.... There's a write up of what was done, and I've probably missed a few things here and there also.
Remember, all your services are bargainable (unless you're SOL with the only Lexus dealership within the next 100+ miles).
$900 at the dealership? I don't mind spending $50 for an oil change. I get a free car wash, good service, relaxing waiting room with all kinds of good stuff to eat and drink. But the last time i stopped in, they charged me $52 for a tire rotation and I went through the roof. That's just plain uncalled for. They are quoting me upwards of $1500 for the timing belt service and I just won't do it.
Other poster already mentioned your GS430 water pump is not on the TSB list.
If taking pictures is a pain in the butt, I would check the coolant reservoir instead.
The reason I took the pictures is I noticed my reservoir went down 1/4 inch. Dealership performed last recall on my GS350 did a pressure test and found no leak.
gs430 won't be easy to have problem. lol. its a good car.
Mine had water coolant leaks about 2 weeks after i bought my GS300 from the dealer. Luckily there was a mandatory 3 mth warranty on the car. Replaced it after they did a pressure test on the cooling system.
You can see from the pics i noticed my coolant tank was empty after two weeks. I did some search on CL and then headed to shine a light on the water pump and belt area and saw pink deposits. So i sent it back to the dealer right away.
