City/Parking Light
I installed these when I replaced my HID to XenonDepot 5000k. Very similar color.
Amazon.com: Sylvania 168/194/2825 Premium White LEDriving Bulb: Automotive
Thanks, I think you've answered my post about the staggered awd setup also, thanks for the info . But I forgot to mention that I'm also lowering the car on tanabe nf210, I wouldn't have to make any mods with my 19x8.5 (+32)front and 19x10 (+38) rear staggered setup right?
I would say NO....
You want to keep these two within spec (I am giving you an example, not telling you what you should purchase literally as I am not a tire guru).
You want to keep these in line, never adjust them when looking for tires:
245/30/20
265/30/20
In other words, From my understanding, you want to keep rolling diameters matching 100% when getting new wheels.
GL!
P.S. You should definitely read up on lowering AWD cars and the driving wobble people have problems with.
245/30/20
265/30/20
GL!
Actually if your widths don't match(wider in the rear) you need to lower the profile to match so instead of a "30" in the rear you would need a "25" to closely match the front diameter. You will have to find a combo that matches as close as possible.
For example I have a 245/35/20 in the front and a 275/30/20 in the rear and they are very close to the same diameter(fronts are slightly bigger).
A 245/30/20 has a diameter of 25.8" while a 265/30/20 has a diameter of 26.3". The added width(265)makes the sidewall(or diameter) larger. These are just examples as I'm not sure what your actual sizes are.
Also a 19x10 with a super aggressive +3 offset is definitely going to require some fender mods. That 19x10 +3 is going to stick out almost 3" farther than stock.
I would say NO....
245/30/20
265/30/20
GL!
245/30/20
265/30/20
GL!
there is some dangerous misinformation here. With those sizes as an example the rolling diameter will not be the same at all.
Now I know, thanks!
