DRL problem
Old 02-09-14, 02:54 PM
ecko1211
ecko1211's Avatar
Default DRL problem
So I noticed my passenger DRL was out the other day and ordered new Putco/9005 halogen bulbs.
I installed both pairs and nothing came on for both.
I then tried taking the driver's side bulb (which works) installed it into the passenger side and nothing again.
I checked the fuse box on the drivers side and everything looks good.
I check the connector wire that plugs into the bulb and see this.
Is this the cause for my DRL to not work? Thanks.
Old 02-09-14, 05:11 PM
XxGoKoUxX
XxGoKoUxX's Avatar
yes, it seems like that is the reason, what you can do is take a multimeter (on DC voltage setting), and check for a 6v or 12v feed.
http://www.ebay.com/sch/i.html?_saca...timeter&_frs=1
You can get them at your local harbor freight store and they'll show you how to set it up for DC voltage if you're not familiar with it
http://www.ebay.com/itm/NOKYA-FEMALE-HARNESS-WIRE-9005-HB3-NOK9105-Pack-of-2-PIG-TAIL-REPLACEMENT-PLUG-/141127291130?pt=Motors_Car_Truck_Parts_Accessories&hash=item20dbd790fa&vxp=mtr
Also, you may have to just cut your losses and order a 9005 replacement harness.
Old 02-10-14, 09:40 AM
ecko1211
ecko1211's Avatar
Thanks for the info!!!. Man, it's a PIA to get to the wire so I don't know how I'm going to be able to replace the wire.
Nokya Female Harness Wire 9005 HB3 NOK9105 Pack of 2 Pig Tail Replacement Plug | eBay
sinstrex
12-23-13 12:02 AM
LA4Mead
RX - 1st Gen (1999-2003)
09-11-12 01:11 PM
anson89
IS F (2008-2014)
11-28-09 07:41 PM
anson89
IS F (2008-2014)
08-16-09 07:38 PM
jpmotdyn
10-27-02 12:58 PM
Quick Reply: DRL problem
