Dash rattle!!!
Old 04-05-14, 12:40 PM
Jjman79
Jjman79's Avatar
Talking Dash rattle!!!
Just completed the dash rattle quick fix I found here on the forum. Here is the breakdown:
quote from dealer to take apart dash-$800
Cost for 4 9"x12" pieces of felt- $1.16
Time of repair- 15 mins
Cost of happiness for no more dash rattles- PRICELESS!!!!
Thanks everybody for the tips, worked brilliantly and only cost me fifteen minutes and one dollar and sixteen cents.
Doug007 (12-12-20)
Old 04-05-14, 05:27 PM
07LXgs350
07LXgs350's Avatar
how big was the felt you put in between the dash? Im assuming you cut it into pieces? Also, what did you use to jam it in ?
Old 04-05-14, 07:49 PM
pman6
pman6's Avatar
I just let it rattle. It's an old car anyway.
And one thing I've wondered is- when you create all that tension by stuffing felt behind the dash, will the clips that hold the dash become looser as time passes....
You might be warping the clips or something
Old 04-05-14, 10:34 PM
Schmexus
Schmexus's Avatar
The felt is like 1mm thick so I don't think it will destroy anything.
Old 04-05-14, 11:21 PM
XxGoKoUxX
XxGoKoUxX's Avatar
It doesn't, metal expands over time and yes, it will warp, but the felt will just compensate enough so that the clips do not rattle.
If you do indeed have dash rattle pman, I'd be totally all about putting felt inbetween to get rid of it.
GL!
Old 04-06-14, 04:45 AM
koffeblack
koffeblack's Avatar
Ok, were is this link to this quick fix?????
Old 04-06-14, 12:45 PM
Jjman79
Jjman79's Avatar
I cut them into 2-21/2 wide strips, keeping the 12 inch length. Used a plastic putty knife I bought from Home Depot for like .99 cents did 2 layers and now there is no noise at all. I'm also from Michigan, so my roads are absolutely horrible, prob the worst in the country. And you can't even see the felt I shoved in...
Lammyyy
11-01-18 05:58 AM
johnnieliu
05-30-13 07:11 PM
Briitini
04-01-13 10:11 AM
Bass Mech
08-04-11 12:35 PM
vertcobra9
03-08-07 10:06 AM
Quick Reply: Dash rattle!!!
