buying new tires ,what should i tell the installer
im bying some continentals dws ,when i get them installed is there a good tire pressure for front and back you guys use in the east coast,also they will take of the dunlop runflats is there a procedure for that so the tire light does not go on
I would think if you have to tell the installer how to do his job, you should probably go somewhere else... ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
As far as tire pressure goes, it's stamped on the side of the tire...
thanks bud ,i have not picked an installer yet just wanted to have info so nothing goes wrong ,is there anything they have to do since the dws are not run flats
My GS is an AWD so I don't have run flat tires but I'm pretty sure there isn't a special procedure when switching tires. The TPMS sensor will only go off if your tire pressure is low and has no knowledge of what type of tire is on the car. You may want to invest in a spare tie because most cars that come with run flats don't have a spare tire.
cool i check the door jam today
i going with continental dws tires $116 each i keep reading good reviews on them ,because my dunlops are so harsh and loud terrible tire
is there any other quiet tires witch run good ,im not looking for performance i have a twin turbo rx7 for that, just comfort
I have the DWS. My second set. First set got 45,000 miles and I could have probably gotten another 10,000 out of them. LOVE them, best tire I've ever had.
I keep mine at 35 PSI.
I just recently went 20's. had the contiprocontact and it was good tire( soft and quiet). Went 1 year 6 month without rotating tires and they still look brand new. My Lexus dealer here kept my tires pressure at 36 or 37 psi
98023IS250
02-26-12 12:50 AM
mjr24
Wheels, Tires & Brakes Forum
09-10-03 05:53 AM
