DIY 2006 Lexus GS300 Alternator HELP!
![](https://cimg0.ibsrv.net/gimg/www.clublexus.com-vbulletin/1670x1243/screen_shot_2020_07_01_at_5_07_09_pm_74c68987a7cbdb4da9ae06454f9d209e0c2e0d1f.png)
1 of these wires is the single wire in the other photo. The other wire is the wire that connects to the alternator.
![](https://cimg2.ibsrv.net/gimg/www.clublexus.com-vbulletin/1653x1258/screen_shot_2020_07_01_at_5_07_29_pm_328468111b990e09ce7be93d25bdf5c904b7522d.png)
You can see the connector here, on the left side of the pic. IT is 1 of the wires where the 2 meet the 1, on the right side. Hope this makes sense. The other in the group of 2(I know, bad description) connects towards the bottom of the engine block. The other of the single wire is 1 of the 2 wires in the other photo. Where the HELL does this black connector plug into?????
You can see the connector here, on the left side of the pic. It is 1 of the wires where the 2 meet the 1, on the right side. Hope this makes sense. The other in the group of 2(I know, bad description) connects towards the bottom of the engine block. The other end of the single wire is 1 of the 2 wires in the other photo. Where the HELL does this black connector plug into?????
![](https://cimg2.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x926/20200701_170604_c4419377bcb1134b365918a95a054616b6235212.jpg)
Wires on my 2006 gs300 rwd.
The big connector appears to connect to ac compressor. See my pic upper right. If that is the case the other 2 wires both go under the exhaust manifold and above the engine support. I cant see back in there. In feeling the wires, one goes to the right and the other to the left. It would appear that you will have to jack up the car or better put it on ramps and pull skid plate for access.
Struggling badly to remove the rear alternator nut, the one on the bracket. Any help greatly appreciated. Where are people sourcing alternators from for the GS300 RWD in uk?
To all the hates of an alternator other than OEM
5 years and 150k on my Napa rebuilt
used anti seize on the put back
god bless all you DIYers you keep America strong
ifinau (12-27-23)
elizbur
05-06-24 10:00 AM
polebarn
12-17-06 03:44 PM
