Hey CL i need opinions on what i would have to do to tuck my wheels in the rear I知 planning on getting Projekt 1痴 20x9 20x11 and wanna tuck like i was tucking my Vossen CV1 which was 9s in the front and 10.5 in the rear which i was tucking and currently I have rolled my fenders which is about it.
Yes you will tuck on air. Just make sure you get the right setup for your arms and links.
remember offset is key also.... you don't want to be -2569234675234 camber
unless if you want to be "camberganged" go with the lowest offset possible
but 15-25 shouldn't be too bad
Thank you for the help would you be able to tell me where i could get the arms and links for an AWD GS350
Originally Posted by Schmexus
What size tires? Seems pretty aggressive for just fender rolling unless you're going to deduct more camber?
I知 thinking of going with the same setup that i had on my Vossen CV1s which was 225/35/20 on the 9 and 245/35/20 on the 10.5 planning on running the same setup on the 9 and the 11s also wanted to know if that would cause any issues on the AWD light coming on.
