GS350 oil consumption guidelines from Lexus
I did a lot of research before buying my uber-pampered '07 GS350, both on the car and the 1GR-FSE. Never did I read about this engine consuming oil. I've just done another search, not finding this as a problem for this engine. Toyo certainly knew about the carbon scoring the cylinder walls, the too-light piston rings, the lack of fuel lubricating and cleaning the intake valves, etc, and this engine was a huge improvement over almost anything on the market, to overcome those problems. Dual injection, port and direct, is absurdly more challenging than the direct-injection engines this replaces, and they did it for a reason. After 30+ years as an automotive engineer, I'm stunned by all Toyota did on this engine, it is a marvel and a masterpiece, and well deserves the many awards it received. It certainly may have flaws, and I'm reading and listening and waiting for any clue that this engine is flawed, I really want to know.
Has anyone done compression tests or boroscoped to see if there are problems with their cylinder walls? That's a pretty simple and obvious check if this is really a problem. Has anyone had one of these engines torn down for this and confirmed the problem? Has anyone with this problem changed out their PCV valve to see if that is the problem? They do go bad and oil consumption is a symptom. On most cars it is a cheap and easy task, something that should be done every few years.
Are there other threads here where owners have made some effort to find out what is going on? What am I missing?
Changed the PCV valve. The oil consumption still happens.
Coincident or not, noticed the oil consumption after having the valve recall done.
And after 35K miles later the consumption rate remains the same.
No miss-firing or high idle RPM. Just top off 3/4QT every 1500 miles.
Yep, this is what I was trying to tell Gotcha350, who insists that only the 300s have this issue. I doubt Lexus was aware of the oil consumption issue in 2005-6 as the 3rd gen GS made its debut, so why would they have bothered to fix it for the 07 2GR-FSE 3.5 engine? Or, worse, what if they did see oil consumption issues with the new 3GR-FSE V6 when they did early endurance testing (I certainly hope they do this for a $50,000 luxury car), and their answer for '07 was to just make it .5 liters bigger and bury their collective head in the sand about the oil consumption issue?
Yeah I wish I had the 350, not the 300. It annoys me that Lexus chose to release the weak sauce 3.0 with only 245 hp, then just one year later build it with the engine they should have had in the first place.
My wife's just hit 100,000 miles. I may have to add half a quart between the 4,000 oil change interval I use, I run about 3 ounces of Redline Si-1 every fill-up. This is great stuff and keeps carbon build up in check.
This engine has both port and direct inject. Shouldn't have to worry about carbon build up ?
That's easy, they stopped testing emissions at the tailpipe years ago... at least here. It's ridiculous, it basically amounts to if the OBDII monitors are ready and you have no error codes you pass emissions.
Does anyone know when it uses direct, port, or both injectors? I've been wondering if it only uses direct injection for certain conditions, and if you happen to drive mostly in those conditions, would you end up with carbon problems? I've driven several cars over 200k almost exclusively on the highway. If these engines run in direct-injection only on the highway, they might not last well under that condition.
I have an 07 GS350 (108k) - 2nd owner, all service done by Lexus. Have owned both previous generations and plan to own a 4th whenever I feel like upgrading. I still love my 07 and don't plan to change very soon.
I would like to say that the oil consumption is getting a little frustrating.
I've had Lexus monitor it for the last 5 months and the consumption is definitely higher than what I would consider normal or "within spec". Got off the phone today with the service manager and was given a new spec that I hadn't read before:
Unacceptable is when the consumption is greater than 1.1 qt /600 miles.
As of my last two checks, it was 1 qt at around 1000 miles and 1.5 qt around a little over 1000 miles.
Seems a little excessive to have to wait until 1.1 qt /600 miles to get the seals replaced doesn't it??
