2006 GS430 Climate control problems
Just bought this car couple months ago for my wife as a commuter car. The other morning on her way she said the heater wouldn't get warm. Couple other things I found not working is the Mode will only blow from the dash vents and will not switch to feet or win. defrost. I also think the recirculate and outside air function doesn't work. The a/c blows cold and fan speed operate just fine.
I had some free time and checked all the fuses, everything checked out ok. I did some searching and I think may need to replace some servos. I found the parts and I see the car has 5 different servos but doesn't say what servo does what. If someone can point me in the right direction on what parts I need , that would be much appreciated.
I had some free time and checked all the fuses, everything checked out ok. I did some searching and I think may need to replace some servos. I found the parts and I see the car has 5 different servos but doesn't say what servo does what. If someone can point me in the right direction on what parts I need , that would be much appreciated.![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
So reading further on old posts, it looks like the issue could be related to servos... anyone has any more specifics suggestions? Would love some more details before I take it into the dealership.
Read this thread. Different Gen but I am guessing similar design.
https://www.clublexus.com/forums/gs-...ml#post4121280
be prepared to get raped at the dealer. I would remove glove compartment and visually see if servos are working correctly
I had it fixed shortly after the OP. I had a friend scan it and came back that the ac/heater control module/amplifier was not operating correctly. I replaced it with a used one off eBay and haven't had problem since.
The part cost me $80 shipped and took 5 minutes to install. It's the red box located under the glovebox.
clentonz
Performance & Maintenance
15
01-02-09 12:16 PM
Floobydust
02-07-07 09:10 PM
