So this morning heading to work the low tire pressure notification popped up. I filled my tires with air afterwards, but the light and notification are still present. Would that reset on it's own, or do I have to do something along the lines of when resetting the oil maintenance message thru the speedometer settings?
Light should reset itself if not theres a calibration switch under the drivers foot well area. set pressures when cold and press the button to reset/initialize the tpms
Thanks for the info!
I didn't see this thread yet so sorry for the late reply. The tire pressure notification went away on it's own
As far as inflation psi, i filled them til about 34-35psi. Is this good? Too much? Not enough?
