Will these wheels fit?
Caution Will Robinson!!!
For 8.5/9 inch rims, the 35 offset works fine. For the rear rims, the offset might be too high, causing the rims to line up with the body and hit the arches when going over bumps. With 10 inch rims, an offset of 43 allows the car to be lowered and minimizes your need for major fender mods. Test fit the rear to see if that's the look your looking for.
I've got a2011 GS350 AWD. Will these 2011 IS350 rims fit? What should I be think about wrt offsets?
http://www.hubcaphaven.com/mm5/merch...egory_Code=625
What are your thoughts on re-manufactures rims?
Thanks for everybody's help.
SC3ooToy
Suspension and Brakes
13
11-22-05 12:53 PM
LexFather
Wheels, Tires & Brakes Forum
01-14-03 06:07 PM
