Transmission Shifting
Old 01-14-15, 12:00 PM
mnjeepmale
mnjeepmale's Avatar
Default Transmission Shifting
2008 GS460
When accelerating from a stop sign/stop light it get's stuck in 1st gear for about 10 - 15 seconds before it shift to second gear. I notice this as the engine rev's high and is not shifting. Shifter is in Automatic and not manual mode. Happened at least 4 times in the past 2 weeks. Dealership is unable to replicate the issue and transmission checks out fine. Guess I have to wait until transmission get's stuck in gear before I can bring it back in.
Anyone else had this happen?
Old 01-14-15, 03:54 PM
BinaryJay
BinaryJay's Avatar
Hasn't happened to me yet... have you been doing regular fluid changes or following Lexus USA's ridiculous guideline of never changing the fluid?
Old 01-14-15, 04:36 PM
mnjeepmale
mnjeepmale's Avatar
Haven't yet. Owned the vehicle for a few months. Fluid change is on my list for the summer.
Old 01-14-15, 08:10 PM
Gotcha350
Gotcha350's Avatar
The summer? That's enough time to destroy what you have left...I wouldn't wait...unless you don't mind possibly having to shell out $4k for a transmission.
Old 01-14-15, 08:35 PM
mnjeepmale
mnjeepmale's Avatar
Transmission and engine is covered under an extended warranty.
Old 01-14-15, 08:49 PM
sam12345
sam12345's Avatar
My guess is one of the shift solenoids
Old 01-15-15, 07:57 AM
hanuman
hanuman's Avatar
I have a similar issue on and off. 08 gs460 50k miles. The tranny just hangs, i had it checked also by dealer could not replicate. No fluid change yet.
Old 01-15-15, 09:03 AM
xms
xms's Avatar
shift solonoid maybe going bad
Old 01-15-15, 11:08 AM
Gotcha350
Gotcha350's Avatar
Hmmm....50k seems like low mileage for an issue but short trips don't let the fluid get up to temp so maybe is causing a solenoid to stick.
It crazy that all these manufactures are coming with this lifetime fluid crap when the manufactures of the transmission like ZF, Aisin, and Jatco don't recommend it at all...as for me...i'll change it every 60k or 3yrs...they just want you to make it out of warranty so they can say you need a new transmission.
Old 01-15-15, 07:57 PM
sam12345
sam12345's Avatar
Did you do a flush recently?
Old 01-16-15, 08:38 AM
warandcar
warandcar's Avatar
so should he flush or drain and fill???
Old 01-16-15, 08:41 AM
warandcar
warandcar's Avatar
how many miles do you have jeep male?
Old 01-16-15, 08:44 AM
Gotcha350
Gotcha350's Avatar
Had the dealer do it at 60k which was 1.5 yrs ago...now I have 66k...id have to go pull the invoice to see if it was a drain and fill or flush. I do remember asking them to just do a drain and fill though...
Old 01-16-15, 11:05 AM
mnjeepmale
mnjeepmale's Avatar
102K miles.
Old 01-16-15, 11:31 AM
GS350Lexus
GS350Lexus's Avatar
If it only happens when the car is cold and only on few beginning shift i would say it is fine, but if it happens after long driver while the car is fully warmed up. Then you have something to worry about.
Quick Reply: Transmission Shifting
