Transmission questions needed
Old 03-04-15, 12:21 PM
BinaryJay
BinaryJay's Avatar
Originally Posted by ta1972
Wow! Still no correct answers? This is getting really frustrating. I wonder why lexus did it this way even tho the trans name is the same, even the gear ratio is the same even for that matter. Maybe it really fits and functions, but don't want us to interchange?? Man, this really sucks! I have already bolted down the trans to my engine already, pretty much 80% done with all this. The sensor plugs and pin count are same and plugged right in. The only thing that was alittle different was the breathe tube on top, but I just switched it out. Also, the trans mount that came with was different. Those were the only things that were different as far as what I saw. I seriously need some answers quick.
Most of the people on this forum are regular drivers and not experts, the fact you've gone as far along with this as you have says to me you know more about this than pretty much anybody else here already. I think you need to get access to TIS and do the research there, if there is anything that can be known in any official sense it will be there.
Old 03-06-15, 12:35 AM
ta1972
ta1972's Avatar
Originally Posted by gr8fulRed
out of curiosity....how many miles are on the car and original tranny? Had you done any service to the tranny prior to the swap??
I had the car for 2 years. The current miles in 145k miles. About 7 or 8 months ago did the trans drain and fill about a few times.
Old 03-06-15, 06:20 AM
gr8fulRed
gr8fulRed's Avatar
had fluid been changed prior to you doing it? How many miles were on the car when you changed it?
Old 03-06-15, 03:30 PM
ta1972
ta1972's Avatar
I did it 7-8 months ago. Don't know the exact mileage on the car at that time.
I just ordered a used low miles ecu. I'm really hoping this will fix it. If not, this will suck big time.
If it ended up being the ecu, why was no symptoms right before I raised the car back up to stock.
The only thing I transferred from the jdm trans was the neutral safety switch.
Maybe the neutral switch is bad? I'm really hoping it's the ecu, since if just ordered it.
This is a mystery.
Old 03-14-15, 12:54 PM
ta1972
ta1972's Avatar
It's finally fixed. Ecu was the issue here. It really pissed me off at first when I replaced the trans to find out it wasn't the issue. Oh well. Now my car runs super smooth with the low miles trans and ecu replacement. At first, didn't know whether the ls trans would fit, but everything worked out.
Old 03-22-15, 06:34 AM
tunedis95
tunedis95's Avatar
Big props for your exploration with this swap.
I've been looking every now and then at the cost of used engines/ transmissions in case i wanted to swap to a lower mileage engine that is, if I ever ran into problems with my original. Nice to know the transmission is a direct swap. Glad you resolved your issue, I would have thought it was the transmission too. I'm very thankful I haven't encountered any major issues with my 2006 GS430 w/145K Miles. (knock on wood)
Old 03-22-15, 11:46 PM
ta1972
ta1972's Avatar
If u ever do a swap using a ls or sc430 trans, just change out the neutral switch.
I changed mine, because the part number was different.
Old 03-23-15, 02:32 AM
XxGoKoUxX
XxGoKoUxX's Avatar
o0o, maybe I should have responded to this a little earlier than I did.
Sorry for not getting on this though..... I recently had a friend with the same issue, he would stop, then the car would jerk forward a bit, then stop again..... It turned out to be the brake's ECU. I told him to do check the ECU just because I figured it was glitched, He took it to the dealer, the dealer took the brake's ECU from another car and swapped it onto his car and it was gone. Bought a new ECU and that was the end of his problems since, his car's now at 2xx,xxx miles w/ zero problems on it. It was passed onto his brother .
Hope this helps other future CL users out later on.
P.S. The dealer was stumped when they kept testing and gave up until I told him what it might have been haha!
SadDie (11-28-23)
Old 03-23-15, 04:06 AM
tunedis95
tunedis95's Avatar
Nice, thanks for the tip. I almost feel as though I would just swap transmissions, rather than pay somebody I dont trust $2k to open up my transmission and rebuild.
ls430w140
01-27-24 06:06 PM
JJMcClure
04-19-19 09:25 PM
Bocatrip
10-18-18 02:57 PM
kaizmauka
05-22-18 07:56 PM
kaizmauka
10-17-17 09:24 PM
Quick Reply: Transmission questions needed
