if that doesn't work ive learned few things that i have noticed from experience.
check to make sure your seatbelt wiring is ok under your seat. ive seen numerous cars have the airbag light turn on because someone accidentally kicked and disconnect the wiring to the driver seatbelt.
ive also swapped in recaro seats to numerous cars with racing harness and the airbag light turns on due to not being connect to the buckle.
i can't say im 100% sure thats your problem because i havent tested it on our cars but its just something id chime in to because i also see your seatbelt buckle light on.
I checked the diy section with no luck …anybody have pics or anything detailed to find the airbag clips under the seats or even a diy to remove the seats I'm assuming the airbag clip is somehow connected to the seat belt anything would help
