Insert and twist....I am not following your question. There is just enough clearance in the front headlamp.
ill try again tomorrow I guess. I fiddled with mine for a while before I gave up because it didn't look like there was enough clearance. Did you do your rear ones too?
I believe I have everything retracted as much as possible to create the most clearance. I know the heat sink is almost touching the plastic housing. Maybe maneuver the relay and wires in the lamp a bit.
I went with carmate led direct replacement for the rear. There is not enough clearance for the v3's in the rear.
