Low tire pressure light on?
Hello
My low tire pressure light came on all tires are fine including the spare tire. i tired to reset the light but no luck. Can anyone help me out? its really annoying driving around and seeing that red caution sign
Did you add air to the tires? I get it periodically even when the psi of the tires are within 32-35psi. I wish Lexus would have included corner read outs for each individual tire rather than having to use process of elimination when needing air. My friends '07 Acura TL had each tire read out for PSI (a $32K car back then). You would think a $50K+ car would have this as standard. If you did add air, then I would agree with above that the TPMS is probably faulty. Check Rockauto.com for replacements since they're cheaper, unless you have a better alternative. Good luck
I'm having the same problem. Although I have 19" wheels with low profile tires. I am thinking it's a bad sensor, but my mechanic says his tpms tool cannot read mine, does it make a difference if they are after market? They're VDO, I thought those are the best...?
My "Check System" light is on and no tire shop can get any sensors to read, and my TPMS system will still tell me if I have a low tire.
Very annoying
Good luck and let us know how it was resolved
Hey guys had similar issues when I switched summer winter set up. We switched out sensors and did all kinds of testing. My car has the 2 sensor button. The only way the tire shops at least discount tire was able to marry the new sensors to the car was to ensure the button was in sensor 1 mode. Which means every time I switch rims I have to take it back for programming usually about 10 min.
CHECK SYSTEM is displayed in the message area and tire light flashes then goes solid
No tire shop can get any of my sensors (or even a new one I bought from amazon) to read with their hand held reader but yet it still communicates with the car computer because it will tell me when my leaky tire goes low.
Anybody have Techstream here in LA that could help me out?
Underneath the passenger side dashboard, close to the center console is a tpms switch that toggles between two different positions. Rarely, a passenger can bump it inadvertently out of position. Check that out. You've really got to get way under the dash to see it. It's marked with the same tire-looking symbol the idiot light looks like.
I'm dealing with the same thing. Car notified me that the tire was low and not 10 seconds later, it blew out. Discount tire did a TPMS rebuild kit and I'm worried that something didn't work right. I'm three hours out of town and they're closed today. The TPMS blinks three times and the pressure inital message appears, then changes back to low tire after I push the reset button. I checked all the tires including spare.
I have been dealing with a TPMS issue for about a month now.
SO sick of looking at that check system message
