2006 GS300 VSC Indicator light
Old 08-18-15, 03:51 AM
Ba0GS300
Ba0GS300's Avatar
Unhappy 2006 GS300 VSC Indicator light
Hello! I've just recently purchased a used GS300 and my VSC indicator light just came on 2 days ago. Anyone know if it is due to poor brakes or...? I'm pretty clueless as to what it could be. Any help or ideas? Thanks!!!
Old 08-18-15, 03:26 PM
XxGoKoUxX
XxGoKoUxX's Avatar
Does the check engine light follow and etc? may be a old gas cap that needs replacing (use gas cap from your dealer).
Old 08-19-15, 03:13 AM
IXI187IXI
IXI187IXI's Avatar
more than likely the gas cap. either not clicked enough or the O-ring is bad on the cap
Old 08-21-15, 10:46 PM
Ba0GS300
Ba0GS300's Avatar
Thanks for the help! brought it into Lexus and got the problem fixed
Old 08-22-15, 05:51 AM
LexusLive
LexusLive's Avatar
Or it could be the beginnings of the dreaded carbon-buildup-piston-ring-failure the GS 300 engine is famous for.
That is a $6400.00 problem. The gas cap is a $6.40 problem. It is funny how the same warning light could indicate 2 different problems whose solutions have such different locations of their decimal points.
Old 08-24-15, 05:42 PM
wickedtaco
wickedtaco's Avatar
Was it the gas cap? What did the dealer tell u?
Old 04-16-16, 12:45 AM
Ba0GS300
Ba0GS300's Avatar
Sorry for the awfully late reply guys.When i brought it into Lexus, they changed the gas cap and the indicator went off but it was only temporary. The light popped back on and off after... I might have to cough up the $6400.00 to fix it after all or... say bye bye cause that's way too much!
Old 04-16-16, 11:26 AM
MX73
MX73's Avatar
Have the codes read from a local auto store and post it up. Or you could have the dealership do a diagnostic and see what the problem is. Has your car been idling roughly?
Old 01-19-22, 12:36 PM
Navila19
Navila19's Avatar
Unhappy Piston-Ring-Failure
So the "Piston-Ring-Failure" Costs $6,400.00?
Wouldn't it be better at that point to just rebuild the whole engine?
JH48
01-20-12 11:25 AM
tunedis95
11-11-11 05:42 AM
thomastan
12-22-10 04:06 AM
tfischer
08-19-05 07:06 AM
GrdnRxR
GX - 1st Gen (2003-2009)
12-22-04 01:59 PM
Quick Reply: 2006 GS300 VSC Indicator light
