To turn or to not turn...
I just got -NEW front brake pads and apparently there is a debate on whether or not to have your brake pads turned.... I wanted to get the groups opinion on this I use a local mechanic that only handles imports and he has his opinion but there are a few engineers that I work with that disagree with his opinion.
Any thoughts or experience with this particular situation?
Former Sponsor
We have never heard of having brake pads turned but if there is any treatment that needs to be done with the new pads is to break them in. This is to ensure that there is cohesion with the rotors; this forms an even layer of the pad material onto the rotors so that to prevent or reduce the occurrence of uneven pad deposit - the main cause of vibration during braking, what most mistakenly refer to as "warping" of the rotors.
There maybe a misunderstanding here. If you meant to have the ROTORS turned, then it depends on much life left is on the rotor and/or if you are experiencing any vibration issues.
My apologies, this shows my level of knowledge on cars..... I meant the rotors turned.
Former Sponsor
Depending on how much the mechanic will charge you to turn the rotors, you might as well direct that money toward new rotors and save yourself from having to spend more money in the long run.
Hope this helps!
If your mechanic tells you that you don't need to resurfacing the rotors, you should find a new mechanic. You always always do it.
Like cquence said, it depends on rotor life left. There is an arrow indicator of where the rotor tells you "no life left." (at least there is on the OEM rotors).
