Minimum offset without spacers
Old 09-03-15, 09:28 PM
GS3fiddy
GS3fiddy's Avatar
Default Minimum offset without spacers
I've searched high and low through old threads but can't seem to find the answer. I'm wheel shopping and all these crazy offsets have me wondering if they would clear my calipers. I'm thinking of going 19 or 20x8.5 or 9 in front and x9.5 or 10 in rear but I can't figure out what offset will clear my calipers. TIA
Old 09-04-15, 05:03 AM
uberEJ
uberEJ's Avatar
Offset doesn't make any difference if it will clear calipers. Disc size is what matters. depending on what brand of wheels your getting, you would have to call the company to confirm that it will fit or get the measurements and go from there.
offset is basically the centering of the wheel to the hub if you look at it from the top of the wheel. the higher the offset the more the wheel is pushed towards the center of the car. the lower or more negative the offset is, the more the wheel is pushed away from the car.
hope this helps and good luck hope you can find your answer to those wheels.
Old 09-05-15, 11:19 AM
GS3fiddy
GS3fiddy's Avatar
Originally Posted by uberEJ
Offset doesn't makes no difference if it will clear calipers. Disc size is what matters. depending on what brand of wheels your getting, you would have to call the company to confirm that it will fit or get the measurements and go from there.
I thought the lower the offset the closer it is to your brakes but apparently I have a lot to learn. Thanks a lot.
Old 09-07-15, 07:58 PM
sha4000
sha4000's Avatar
These should help you understand better.
http://www.tirerack.com/wheels/tech/...jsp?techid=101
http://www.1010tires.com/Tools/Wheel-Offset-Calculator
Old 09-08-15, 05:10 AM
uberEJ
uberEJ's Avatar
it really depends on the wheel. like with the links above. ^ ^^^ it seems like some companies use offset to clear brakes. but i guess if this were the case i would say +28 offset could be your lowest. but again it matters on the design of the wheel.
what wheels are you looking at anyway if you dont mind me asking?
byefi
03-28-18 08:39 PM
Tom57
11-23-15 12:33 PM
gp1300r
10-28-15 08:06 PM
pnwIS250
02-15-15 01:49 PM
moose66
10-23-11 01:43 PM
Quick Reply: Minimum offset without spacers
