New Water Issue
I've read all the threads about what causes the mats to get wet inside the car. My sunroof drains are clean and clear, the a/c doesn't cause it, rain doesn't cause it, however, whenever I go to my car wash, it soaks the rear carpets. I'm assuming it's the high pressure under-carriage water that gets in. I'm just not sure how or why. If it's a problem or the car wash's fault. I need to get the water out and the carpets dried asap. Do I just not wash my car anymore?
I believe the older 06-07 GS's had an issue with evaporator drip drain being clogged up. Theres a trick to unclogging if your car is one
If theres very little water in the car you can use a wet n dry vacuum and vacuum the water. Then with the vehicle outside on a hot day let the car idle with the heater on full blast and have the vents aimed at the carpet. Also put the sunroof in the raised position the heat will heat the water and it will evaporate out of the sunroof crack. Leave it running for an hour and should be all dry.
If theres lots of water in the carpet, then you can pop open the molding trim strips raise each corner of the carpet and vacuum under the carpet. Then do the heating method
The water is coming from the car wash though. Are you suggesting that this evap drain being clogged could be causing the large amounts of water inside the cabin?
The seals are in good condition.
I will be able to hand wash as soon as I move into my house and out of this ***** apartment renting situation in two weeks thank goodness.
gandro
Automotive Care & Detailing
12-02-09 09:25 AM
