2007 GS 350 90k Service
Old 02-24-16 | 05:41 PM
ntx's Avatar
ntx
Default 2007 GS 350 90k Service
I've got 90,000 miles on my GS and I'm confused about the timing chain and 90k service. I looked at lexusdrivers but I didn't see anything that called out a timing chain replacement in the scheduled maintenance section. I've also seen some people online say that the timing chain should last the life of the car. I know last time I was in for service the advisor commented that the next one would be a big one. Should I expect the timing chain replacement or is that only in extreme situations? Can someone compare the typical cost of a 90k service at a dealer vs. an independent lexus specialist?
Old 02-24-16 | 08:11 PM
Lukas99GS's Avatar
Lukas99GS
Timing chain won't be touched, I believe the 90k service includes the water pump, coolant flush, brake fluid flush, and possibly spark plugs. I'd imagine it would run around $1000 at a dealer maybe 700ish at an independent
Old 02-24-16 | 10:59 PM
msgs350's Avatar
msgs350
How long have you owned the car? What have you or the previous owner done already?
Go independaent if you can, but make sure they use OEM (Toyota/Denso) parts. Expect around $1k for the water pump, tensioner and belt... etc. . Spark plugs is a toss up, some people do them at 60k, some do them around 100k. Now is a good time to get all the fluids changed if you haven't already.
Old 02-28-16 | 05:05 PM
ntx's Avatar
ntx
Thank you both for the replies. I've owned the car since June 2009 when I bought it from a dealer as a CPO car. I've only taken it to the dealer but not sure how much longer I will keep the car so that plus the age seems like a good time to explore a dealer alternative. If anyone has any experience with Davenport Motors in Dallas I would like to hear your opinions. They seem to be a larger lexus specialist in the area.
Matsui
GX - 1st Gen (2003-2009)
28
02-11-22 03:27 PM
Datguy
02-14-13 08:41 AM
ted920
05-08-12 08:57 PM
Gil Smash
09-14-10 12:16 AM
hlb
06-07-10 03:08 PM
