Lexus GS 350-9005 DRL led bulbs
Old 05-02-16, 07:11 AM
jwickens
jwickens's Avatar
Default Lexus GS 350-9005 DRL led bulbs
I purchased some A/M DRLs bulbs and they flicker when they're on. When I use them for my high beams, they work perfectly. I've purchased 4 different types, some with and some without the decoder. None work correctly.
My question- Which brand works if any and is there anything special needed to prevent the flicker? it's a 9005 led bulb. Thank you in advance.
Old 05-02-16, 09:28 AM
dfkd
dfkd's Avatar
Search online for an R4 decoder.
I'll make the required mention that even though your high beams will "work", they're no longer useful as proper high beams and may actually be illegal.
Old 05-03-16, 05:53 PM
YxUxMADDDD
YxUxMADDDD's Avatar
I was worried about that as well.... Good thing I purchased my first and only set of decoder that worked. Seller on eBay is "partsbox" and it was $9.79 per decoder (at the time I purchased it earlier this year) and you need 2. Try them. Hope this helps.
Old 05-04-16, 11:37 AM
ashley1977
ashley1977's Avatar
Got my wire and decoder from V-LEDS few years ago, no flicker and works perfect bright enough as DRL but not as high beam.
Pictures shows here are the 28 leds 9005 bulb from V-LEDS, and youtube video is 2015 Cree led 9005 bulb with the same setup (wire harness and decoder). Anyway I removed it and return to stock with H.I.R bulbs, because with old 28 leds not bright enough for night time use, and 2015 cree led too bright as DRL.......
Attached Thumbnails Lexus GS 350-9005 DRL led bulbs-mobile01-b1b8ac74e607d1ca5348bc14b55f062a.jpg   Lexus GS 350-9005 DRL led bulbs-mobile01-34ddda7582303071ebe547a2d070d387.jpg   Lexus GS 350-9005 DRL led bulbs-mobile01-91b0eec003716c493e5a3d6632ea8ba0.jpg   Lexus GS 350-9005 DRL led bulbs-mobile01-3222839f89c696f2759bd9dd299a8ff4.jpg   Lexus GS 350-9005 DRL led bulbs-mobile01-3bba17e05c16b7c62113c973efa9a32f.jpg
Lexus GS 350-9005 DRL led bulbs-mobile01-de796c9a69174181d2afe6710fa71807.jpg
Old 05-04-16, 12:01 PM
dfkd
dfkd's Avatar
Interesting. Very different from my module.
Mine simply plugs in between the harness and the bulb.
No battery and ground connections for me.
I live and drive downtown 95% of the time. When I'm roadtrippin' I swap back to halogens I keep in the trunk.
Takes 10 mins.
Old 05-04-16, 12:28 PM
ashley1977
ashley1977's Avatar
Takes 10 mins.
Yeah on 2009 V-LEDS has low power 68 leds 9005 bulb, it works fine with just the decoder in black color, one bulb each, but on 2011 V-LEDS has new version brighter 28 leds 9005 bulb, require the harness and one decoder only in order to avoid the flick. The harness also works perfect with 2015 cree led 9005 bulb as DRL.
Lexus GS 350-9005 DRL led bulbs-mobile01-506917cdd96dcd982917da7135159c72.jpg
Lexus GS 350-9005 DRL led bulbs-mobile01-9cb5096b10027957bd6b1b0e47d967b8.jpg
Old 05-04-16, 09:10 PM
tcr101
tcr101's Avatar
Not sure if you switched out the wedge bulbs, but I noticed those were the ones that flickered. If your looking for LED high beams, I ordered from HID Powerhouse (a sponsor)
They looked something like these:
High beams are bright and definitely work as high beams. It seems on cold starts sometimes the LED chip bulbs (168 style bulb) will flicker, but once the low beams are turned on they do not flicker.
Old 05-11-16, 11:13 AM
jwickens
jwickens's Avatar
Thanks for all the help.
RobertGift
Lighting
07-19-16 04:51 AM
dhuynh15
07-17-15 12:21 PM
xRYD3Rx
06-03-14 02:07 AM
kingz415
07-24-12 08:44 AM
italiandud
12-08-07 11:33 AM
Quick Reply: Lexus GS 350-9005 DRL led bulbs
