Intermittent headlamp out
So this is the second time this has happened, so before I start buying and replacing stuff I figured I'd ask:
I don't keep my headlights on Auto, I just turn them on and off when it starts getting dark or whenever.
First time I turned my headlights on in the morning (the automatic feature probably would have kept them off) and when I got behind a car at a light it appeared my right headlamp was out. Hmm.. okay it happens, right? Well before I went home that evening I turned on my lights and went to the front of the car - both were on and stayed on the entire way home.
Since then no issues.
Yesterday I turned my lights on and left around 6 (again, the automatic feature would have kept the lights off) and when I got to some traffic I noticed the right lamp was out again. When I got to my destination I got out and checked - sure enough it was out. So when I left that evening I turned my lights on and both were on for the entire way home.
Could a ballast be going?
Bulb is on its way out. That's how they act when they're dying. Just replaced my passenger side this weekend, and thought my driver's side was bright until I saw them reflect against the garage door, so ended up ordering a second for the driver's side, which I'll swap out this weekend. Below is everything you'll need:
Part to order:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
How-to:
Part to order:
How-to:
It hasn't done this since I made the post, lol.
The car was also smacked in the front by an exploding semi tire so it was in the shop for a bit. Now that I have it back I need to swap the bulbs and test things out
Part to order:
How-to:
2008 Lexus GS 350 headlight replacement part 1 - YouTube
Part to order:
How-to:
Glad you were able to get this done, and for a lot cheaper than what the dealer would charge
I am having the same issue on my 08 GS350, but sometimes it's the left side and other times it's the right. If I flick the switch from auto to on to off back to on they will both come on, then a few minutes later one will go out. Any ideas why both would be intermittent like that?
thanks for the reply, I am a little nervous about that link, there are a lot of negative reviews on their about them being fake and only lasting a short time, or worse. Is Xenon Depot a better option? I see them on the forums, they want double what amazon is asking but I guess I would be willing to pay if I knew they are legit. Just asking cause I really can't afford to do this twice, it's hard out here man!
Could always try these (a lot less reviews, and not sure if they're any different):
https://www.amazon.com/PHILIPS-4300K...ds=philips+d4s
I replaced both of mine in the 2006 GS 430 with the factory Phillips from Amazon at 2 for $79, and guaranteed genuine. The real ones have a unique verification number for each bulb made on the box you can check against the Phillips website. I checked out the ID number to be sure so if they were fakes I could send them back. Work great and saved a ton off of the $210 per light plus install the dealer wanted.
