Front Differential fill bolt
Old 10-24-16, 04:44 PM
Othic
Othic's Avatar
Originally Posted by ServerTech
Yes. It's part of the transmission and uses the automatic transmission fluid. Just drain and fill your transmission.
https://www.clublexus.com/forums/gs-...ml#post9649296
False. It does not use transmission fluid. It uses gear oil.
Old 10-24-16, 05:11 PM
ServerTech
ServerTech's Avatar
Read the service manual Junior:
Attached Thumbnails Front Differential fill bolt-transfer1.jpg   Front Differential fill bolt-transfer2.jpg   Front Differential fill bolt-transfer3.jpg   Front Differential fill bolt-transfer4.jpg
Oceans13 (09-01-21)
Old 10-25-16, 04:52 AM
Othic
Othic's Avatar
Sorry. Thought they were talking about the front diff, not transfer case.
Old 09-01-21, 06:37 AM
LxSBase
LxSBase's Avatar
Default Don't give up!
Originally Posted by acegunter
I changed rear diff fluid but not able to reach the fill bolt for front diff... Can someone plz hel..
I just purchased a 3/8 drive stubby Rachel from O'Reilly that might do the trick, I will update later. Low profile rachets may work as well. The clearance is tight yes but a low profile or stubby should do the trick.
Old 09-01-21, 05:10 PM
LxSBase
LxSBase's Avatar
ok so the stubby didn't have enough clearance but after I took the nut off and moved the bolt to the steering rack and pushed the assembly straight up I got more clearance it was better. I was rushing for time but maybe with the other bolt out I have have been able to tighten the fill bolt better. Bottom drain bolt got stripped 😥 but I was able to top off fluid.
Remove 19mm nut
Push bolt through
Like this or just remove
See!
Spoiler
More clearance
wvuguy
RX - 1st Gen (1999-2003)
34
12-12-17 04:22 AM
Rocknrose
06-28-16 04:55 AM
volson
10-17-15 08:05 AM
philipf22
GX - 1st Gen (2003-2009)
15
03-17-15 04:35 AM
Jabberwock
09-03-13 01:23 PM
Quick Reply: Front Differential fill bolt
