How much should one pay to change Differential Fluid?
Old 06-13-16, 11:29 AM
wickedtaco
wickedtaco's Avatar
Default How much should one pay to change Differential Fluid?
What's a reasonable price to change the Differential fluid in a 06Gs430?
The Toyota in Panama City, Fl states it's $270-$490 depending on what they find after they inspect, clean, lube and flush. (sounds like a bunch of BS).
I told them I just wanted it drained and filled not a rebuid!...
I believe the differential holds 1.4 qts.
Plz chime in
Old 06-13-16, 11:36 AM
RXGS
RXGS's Avatar
I know my dealer charges $99 per diff. I paid an independent $60 for labor and got 3qrts of Valvoline gear oil for $28.the rear is easy to do, but based on seeing the front done, a lift would be very handy because of where the fill bolt is. Just realized you had a 430, since you are only doing the rear, most places shouldn't charge you more than. $100 and you could probably do it on your own. For my 300 it held about 1.5 quarts, might be different than yours
Old 06-13-16, 06:14 PM
gr8fulRed
gr8fulRed's Avatar
if it's ANYTHING like my 09' 350.....replacing the rear diff fluid is total cake. DIY tutorial on here made it super easy. I mean, literally... drain it, and fill it back up. You may need a low profile jack and some wrenchs/sockets...but takes maybe 30 mins.
Old 06-13-16, 06:49 PM
brucelee1
brucelee1's Avatar
$90 or so.
Old 06-14-16, 02:33 AM
ibidu1
ibidu1's Avatar
Crooks! Changing a differential fluid is easier then an oil change, uses less oil.
Old 06-14-16, 05:02 AM
burny
burny's Avatar
Undo fill bolt first, then undo drain bolt and drain into a pan. make sure car is level and get a $5 hand pump from Walmart and a couple courts of Mobile 1 synthetic gear oil and you are done. 15 minute job. Gear oil and hand pump total cost is about $25
Old 06-15-16, 01:25 PM
YxUxMADDDD
YxUxMADDDD's Avatar
It's $300 here at the Toyota in Plano,TX. $600 for ALL fluid flush, fill, and oils change with "Toyota" additives. That's so call hooked up from a referral.
Old 06-15-16, 03:29 PM
PoppFlyy
PoppFlyy's Avatar
I did my transmission and differential drain and fill at the same time and it was about $125.
Old 06-15-16, 04:25 PM
Bradlar
Bradlar's Avatar
I just had mine done at Park Place Lexus in Grapevine ~ $100
Old 06-27-16, 02:35 PM
Rocknrose
Rocknrose's Avatar
Is there a gasket to replace?
Old 06-28-16, 04:54 AM
burny
burny's Avatar
yes, it is like a dolla fiddy
Stemmer
RX - 1st Gen (1999-2003)
13
11-20-21 09:55 PM
RX3302004
10-25-15 07:21 PM
BlueCrabby
09-04-15 07:10 AM
Poqman
05-30-12 06:07 PM
bizzy928
Performance & Maintenance
12-30-08 08:54 AM
Quick Reply: How much should one pay to change Differential Fluid?
