Tire recommendations for ride/treadlife ?
The Michelin Pilot Sport 3 A/S's are all but done. I'm with a few thousand miles of these tires being shot and they will have about 43k on them. The tire is a 45k mile rated tire. Car always kept in alignment, rotated every 5k like clockwork, proper air levels, etc...plus...70% of my mileage is probably highway, so I kind of expected to get 45k easily...maybe even with miles to spare as I have often with other tires. I'm looking to sacrifice a bit of performance (handling, cornering, etc) for better tread life and as forgiving a ride as possible...while still staying with an OEM size tire (245/45/18). I'm leaning towards the Continental Pure Contact. Has good reviews and a 70k tread rating. Anyone have any experience with these on the GS's?? Good, bad or indifferent?? Any other tire I should consider for what it is I'm looking for?
Thanks !!
Thanks !!
I had purchased (recently) a set of Michelin Pilot Sport 3+ A/S.. This is the new generation of Michelin's Pilot A/S. So far, as they break in, the ride is formidable, forgiving..
The side walls may be a bit soft for this vehicle. These are also very quiet on most any road surface. As far as mileage, I keep these at 30lbs., and am getting around 23 local driving to upwards of 32 on the hwy (average). I would recommend these..
Thanks !!
Thanks !!
damn, that's great that you're almost getting full life out of your tires.
I have conti DWS on mine, and they're half gone already with regular rotation every 5k, and I haven't even driven 12000 miles on them. Most of my driving is local though, so lots of turns and such.
it's a 50k rated tire, came with 11/32 tread, and I'm already down to 6-7/32 after 12k.
I don't expect to get even 30k out of the DWS, just like the factory dunlops it came with.
I don't think the camber and toe gives us good tire life
So I have a 2 part question. I got a flat tire last night. Took it to the local Discount Tire and they are saying its not repairable and need to be replaced. Now I have 2 options, either just replace the 1 tire which is a Dunlop 5000 run-flat for $350 or replace all 4 of them with Yokohama YK740 All Season Tires with a 60,000 mile warranty for about $775.
So my question is a) I purchased the 2009 GS 350 last year as a Certified Used Lexus so still under the L-Certified warranty and when I look at the service history, looks like the previous owner had all 4 tires replaced in Feb 2014 at 27000 miles at the Lexus dealer where I purchased it from. so will this by any chance be covered under warranty? I am currently at 37000 miles. I called them and they are asking me to bring it in for them to take a look and its a 2 hour drive that I will have to make while on my spare wheel that I am only going to make if I have more than a good chance of this being covered and not them trying to just sell me a new tire.
And say, if with my luck, it's not covered under warranty then, b) Should I replace just the 1 damaged run-flat with same or go ahead and replace all 4 with all-season. Just trying to figure out how much of a ride difference will it be.
Are all season tires better on the GS ?
Thanks in advance.
Hasman69.
Thanks in advance.
Hasman69.
Thanks in advance.
Hasman69.
Thanks in advance.
Hasman69.
Hope this helps
Thanks in advance.
Hasman69.
Thanks in advance.
Hasman69.
I have been looking all over the internet and even at TireRack.com unfortunately not too many reviews on the GS.
I had my mind set on the Continental ExtremeContact DWS06 until I saw the TireRack Test video. Now I am starting to lean towards the Pirelli P Zero but from the reviews I read, not too good on the snow
Is it too much to ask for a quiet all season tire with good wet/dry and snow traction without loosing on the sporty feel ?
SILENTM - Thanks for the info.
Gr8gulred - Have you decided on which ones to go with ?
So negative on the warranty, I guess I am in the market for 4 new tires.
So went to Discount Tire today and got 4 new Continental Extreme Contact DWS06 to replace my run flat Dunlop 5000.
Just drove back home and I already hate them. The ride is too soft and mushy.
I believe Discount Tire does exchanges, or atlease I am hoping they will.
Seriously thinking of going back to the Dunlop run flats, but really dont want to spend $1400 on 4 tires.
MrBk - Let me know once you get the Pirelli P7 installed. First impressions on the ride.
The GS has a sporty ride and I dont want to loose that. I was hoping for something a little more quiet and a little less stiff but not be mushy.
