so i rubbed up against my is300 on accident. need some advice on paint
just like the title says. i accidentally rubbed up against my is300 and the rear reflector scratched my bumper and fender a little. its not that bad to where i need to repaint the entire bumper but i do want to touch it up to hide the imperfection. lucky my car is white and having to blend it perfectly isnt so much of an issue. i stumble across this website trying to find a paint solution and i just want some opinions about how im going to go about it. im going to mask the area that needs touching up and using a paint matching aerosol spray to repair the area. let me know what you think
https://touchupdirect.com/touch-up-p...&tud_year=2006
If you don't really care, just leave it. If you do care enough to paint it yourself, take it to a body shop. If you do it yourself and you don't have experience with automotive paint work, you won't be happy with the results.
ill swing it by a body shop for a quote. the experience i have with automotive paint is painting my engine bay of my integra a different color a few years ago. ill ask my bro i just remembered he use to do body work.
I would use rubbing compound to get off as much of the black stuff as possible and then just touch up the areas with a touch up pen where the paint was actually taken off. Some people then wetsand that too smooth it down, but I've never done it.
If you just clay/buff/polish you'll get a good chunk of it out. Just pick up a bottle of Meguiar's Ultimate Compound and go from there
ive had good luck with WD40 or gasoline. Then compound. A lot of mobile pdr guys offer spot jobs like that for under $200.
Grab some laquer thinner and clean it off try to get as much off as possible. Then I would do the touch up paint!
That pearl white is the most difficult color to paint out of all the paints. Pearl White is a very hard to color match! Experienced painters have trouble with it
