2006 lexus gs300 engine light on
Old 11-17-16, 09:07 PM
crown0228
crown0228's Avatar
Default 2006 lexus gs300 engine light on
Please I need some help on how to handle my 2006 lexus gs300 . The engine light came on with check vsc and abs light and show its slippery. First I took it to autozone and they said I should change the o2 sensor which I did and all the light went off and came up like 3 hours after
Old 11-18-16, 01:56 AM
Sodium
Sodium's Avatar
First, welcome to CL!
Yeah that sounds like bad advice, I don't think a faulty O2 sensor can cause VSC/ABS issues since their functions are completely separate. As for the lights going off for a few hours after the O2 sensor replacement, the battery was probably disconnected during the job, and that will clear the error codes – then presumably whatever fault triggered the code the first time caused the lights to come on again
You'll probably need to give us a bit more info. Firstly, did anything notable happen right before the lights came on (for example: oil change, major service, tire replacement, collision, etc.)? Secondly, how did autozone conclude that you needed a new O2 sensor? Also, did they pull any codes – if so, could you post the codes here?
Old 11-18-16, 08:04 AM
SILENTM
SILENTM's Avatar
Probably got p0420, p0430 codes. Auto zone should not be giving you advice on what to replace. Are they going to pay for the o2 sensors now that they misdiagnosed
Old 11-18-16, 09:45 AM
RXGS
RXGS's Avatar
I could be an O2 sensor, but potentially the wrong one. Try getting the exact code from them.
Old 11-18-16, 10:30 AM
ibidu1
ibidu1's Avatar
Sounds to me like carbon buildup issue!
Old 11-18-16, 03:45 PM
doobs01
doobs01's Avatar
I just had this same issue happen to me today. I left the radio on while i was cleaning out and vacuuming the car. I went to start the car to leave and the battery was dead. I got a jump from a nice gentleman, but now i have these same lights on after turning the car off and turning it back on. Mine is an 07 gs350.
whoyouknow
12-13-18 12:26 PM
eastredsc
03-08-17 08:50 PM
daddio054
11-18-13 08:25 AM
craigsroto
04-16-13 10:46 AM
kramo
05-19-06 03:01 PM
Quick Reply: 2006 lexus gs300 engine light on
