Help! Low Tire Pressure Indicator light on.
Hello, I could sure use some help in getting the low tire pressure indicator light off my dash.
I have aftermarket wheels and all tires are @ 36psi. I then pressed the reset switch that is under the drivers side dash. Unfortunately, the lisht is still on.
Can anyone help?
thanks
Can anyone help?
thanks
Get a Toyota Techstream cable and program the TPMS yourself.
Its $25 on eBay/Amazon.
You can also customize a bunch of stuff, read proprietary codes and program keys.
It'll pay off for itself in less than one trip to the dealer.
thanks for all who have chimed in. Update: I inflated all tires to 40psi and then deflated 4lbs per tire. started car and saw the cluster read initialized system. Took the car for a spin and no light on dash.
I plan to order the Techstream because I would like to disable the automatic steering wheel feature along with the DRL.
