2006 GS300 Shut Down On Me...PLEASE HELP!!
Hi, All,
I NEED HELP!! A few days ago my 2006 GS300 AWD shut down on me on the highway. The dash panel display started to flicker off and on, the check VSC warning came one, the battery icon, check engine lights, and other dash icons came on and I was barely able to pull it to the side of the road. I tried to jump the batter but it wouldn't jump so I went and bought a new battery and that did the trick (the rep at the auto store checked the old battery and it turns out I had a bad cell). Later on that evening however, driving on the highway again the same thing happened. This time though I was able to drive a few more miles before the car completely shut off again. Now it will not start at all. i am assuming it is electrical because although I have a new battery, it seems power is not getting though as, for example, hazard lights won't stay and blinks weakly and when I turned on the wipers and they barely moved.
I have an idea that it may be the alternator. I did some online research here and Google and YouTube and it suggests that it is, but I am not sure. Can anyone offer advice? Assuming it's the alternator, right now I do not have $800 for parts and labor to replace it. I would like to DIY. Can anyone provide videos or tutorials regarding replacing the alternator on my own? Please only helpful, detailed and respectful comments. Thank you.
If you can take out the alternator, have someone like Autozone, O'reillys, Napa, etc, test it out. But with all those warning lights, especially the main three, VSC, battery, and CEL it is the sign of a bad alternator. Mine did the same thing a few months ago. The part is cheap, but taking out the alternator is a different story. It's a pain in the butt.
mekonoir (12-24-16)
Thanks MX. Is there anyway to test the alternator without having to take it out? I saw some vids and yes, I agree with you, it's a pain in the butt apparently. I saw that you can test the alternator with a multimeter but that's only when the car is running. If you know whether I can test the alternator without having to remove then let me know. If not, I just have roll up my sleeves and remove it myself to be checked.
Thanks for your quick reply too bud!
Take it to advance or autozone and have the guys run a scan on the alternator their system should be able to tell you if the alternator is any good or not.
If your low on cash maybe you can try to rebuild your alternator they sell brushes and regulators on ebay http://www.ebay.com/itm/100-NEW-ALTE...BWTT0k&vxp=mtr
mekonoir (12-24-16)
Just to chime in also, it definitely sounds like the alternator 100% too. I've had this issue before on other cars such as my sc300. Basically the alternator is not charging the battery as it should and thus the battery is supplying all electrical power to the car like your radio, lights, etc. You can imagine a couple drives here and there with radio on and it will deplete that battery quick. Good news is that new battery might be salvageable or if you got a good one, may qualify for the replacement maybe at no cost since its so new.
Good luck and let us know how it goes.
Hi, All,
Alicater
04-26-16 06:34 AM
worbird
09-27-15 10:17 PM
