Blowing lot heat/air
Had this issue for a while so I got kinda fed up, I turn on the heat and ac, they both work but I would have to put it to medium(M) to feel anything. 1 and 2 is like non existence. Any ideas what it can be?
Next steps I would check is of course the slider wheel next to the vents; I know silly question, but it have come up before where this was turned low and many times have been asked why the ac is not on.
The actual blower motor itself could be going out; if you have an amp meter, measure it and if I can remember most of these are rated for 10-15 amps. Anything lower could be a sign its going to start going bad on you.
