Navtool
Curious is anyone here has installed navtool in their GS and has instructions or advice? Not many FIYs and the ones out there are mainly for the SC430. It seems simple enough, but all the wires are a bit intimidating. Thanks in advance. 2006 GS300 without nav btw. I've installed GROM and Viastech before so I have some sort of familiarty, but this is a bit more involved
According the their site, its' plug and play and requires a 12v and ground only that you will have to mess with. Sounds simple enough and it doesn't seem like that much of an issue. I glanced over at the sc430 and it does look a little more involved, however the gs series seem to be simple.
the unit itself came with a wiring harness that looks to have much more to be done than a simple ground and 12v power, but you may be correct. I'll take a look at it again. There was someone who installed a unit in his 2006 GS in about an hour, but that was in 2010 and unfortunately he hasn't logged on since 2013 so no advice there ha
i had it in my jag but updated it
i have ivic in my 2010 gs
to wire up navtool you have to find you rgb sync wires then tap into that ,you can use it on most cars then a touchscreen overlay
^ I just have to make sure I use the right plug to tap into. As for the model, I have the newest 3.0 so there isn't much out there in terms of installing it, at least for Lexus. I'm going to use a USB for my iPhone and one of the video inputs for a rear view camera
what you can do is get a android box with all the apps ,theses boxes has screen mirroring and usb and micro sd card input
then you need to cut the plug with rgb sync wires and tap in there once you find the plug go from there
GammaLex
06-01-07 10:38 AM
