Sirius Satellite Radio
I recently bought a 2006 GS430 and was looking through the service records on the Lexus website and saw that it had Sirius installed. When I switch to Sirius on the radio, it shows channel 184 and doesn't let me change to channel "000" to get the code for Sirius. I checked the trunk to see if the box for the Sirius transmitter was there, and I don't see it nor do I see the antenna. I did read that some of these were installed under the rear deck lid. Does anyone know if there is a way to determine if the car actually has the equipment without going to the dealer?
REPAIR# 0059648
REPORTED BY: Lexus of Thousand Oaks
SERVICE: INSTALLED RADIO
DESCRIPTION: INSTALLED RADIO ~ ~INSTALL SOP SIRIUS RADIO (EST. $650.00 + TAX) ~ ~. ~ ~INSTALLED RADIO
9684 MILES
DATE: 12/30/2005REPAIR# 0059648
I'm not sure if you have ML but in my 2008 GS 350, the XM module attaches to the ML Amp which is on the right side of the trunk....either the floor or the side underneath the trunk lining. I would start checking there. I also have the shark fin antenna so I'm not sure where the antenna will be located on 2006.
