DIY: How to access blower fan servo's
Old 02-28-17, 03:45 PM
xbladex00
xbladex00's Avatar
Default DIY: How to access blower fan servo's
Hey guys here's a DIY how to access the blower fan and the servo. Some of you may have broken the servo arm or need to just access the blower fan and here's a DIY for it. (I HAVE NOT BEEN ABLE TO FIX THE SERVO ARM SO IF SOMEONE HAS ANY INFO ON IT THEN PLZ ANY WOULD BE HELPFUL)
LETS GET STARTED: YOU'LL NEED:
- UNPLUG THE BATTERY
Cross screw driver
- 10mm socket (maybe might not just bring it incase)
- EXTENSION (MAYBE)
- 10 MM WRENCH (MAYBE IF U ALREADY HAVE THE SOCKET)
- interior trim remover
STEP 1: PRESS THE FOOT BRAKE, PUT THE CAR IN NEUTRAL SHUT OFF, UNPLUG THE BATTERY FROM THE TERMINALS
Here are the tools I used. i believe that is a 10mm wrench, you may need an extension just in case.
put your car in neutral DONT FORGET TO PRESS IN THE FOOT BRAKE
STEP 2: pry carefully here on both side's as you'll be taking the entire assembly out. there should be 1 in the back 2 in the side.
STEP 3:on the right side, you'll be removing about 2 screws
STEP 4: this pops right out on the passenger front side
STEP 5: you can just pull this down from the vent area
STEP 6: you can unplug these wires but i just left these lying on the floor
STEP 7: UNSCREW HERE
STEP 8:unscrew here the 2 bolts
STEP 9: UNSCREW HERE
step 10:UNSCREW HERE THE TOP ONE AND THE BOTTOM ONE. I THINK YOU CAN LEAVE THE MIDDLE ONE ALONE
step 11: I JUST LEFT EVERYTHING LAYING DOWN TOO LAZY TO UNPLUG THIS STUFF BUT THAT'S PERSONAL OPINION
STEP 12: unscrew the 2 black screws i think the silver one doesn't matter
STEP 13:UNSCREW HERE, there maybe more than one in the glove box so look around
STEP 14: unscrew this here, i'm not sure what that is TBH. the black part is the servo and the arm is in-between the 2 i just mentioned
here's a full pic of what everything looks like, I MAY HAVE FORGOTTEN TO TAKE PICS OF THE J VENT GOING TO THE FLOOR HERE U CAN SEE THE SERVO ARM CONNECTED TO THE SERVO
THIS IS THE SERVO ARM THAT BROKE
HERE'S A CLOSER LOOK, THE TOP IS THE FILTER DOOR PART
HERE LIES MY ATTEMPT BUT IT ENDED UP BREAKING ANYWAY. I USED EPOXY 11 DIDNT WORK IDK WHAT TO DO
HERE LIES MY ATTEMPT BUT IT ENDED UP BREAKING ANYWAY. I USED EPOXY 11 DIDNT WORK IDK WHAT TO DOI hope you guys enjoyed my DIY, and if you guys have any tips or info please comment! Thanks for looking!
The following 2 users liked this post by xbladex00:
Farqui (03-01-17), ptplujo (02-28-17)
Old 02-28-17, 07:10 PM
Gs3500
Gs3500's Avatar
Are u able to screw a fastener to attach?
Old 02-28-17, 10:35 PM
xbladex00
xbladex00's Avatar
I heard from the other post on 2IS side, that someone did it and it worked fine... I'm not sure if I want to try that. I want to know whats the strongest bonding thing ever and use it... The fasterner is probably the last option kind of thing lol
Old 03-03-17, 01:25 AM
HaerdenC
HaerdenC's Avatar
These are the kind of parts that are very hard to get and most of the time very expensive ... while they are perfectly 3D printable with reinforcement. I really really really need to start looking around to get me one
Old 04-14-17, 03:38 PM
xbladex00
xbladex00's Avatar
I'm Not sure but the piece connects to the Door as one whole piece or the entire stick like actuation. I need to remove it again to check. at this point i'm a pro at doing this lol.
Old 10-15-17, 04:56 AM
topperdogg
topperdogg's Avatar
Interesting thread. Are we talking here about the servo that selects where the air goes to, or the servos that handle temperature and recirculation?
Because I have a problem where whatever I press air is only blown to the windshield. I see lots of threads on how to fix this for the 2nd gen GS, but few on the 3rd gen.
The dealer told me today that there are three servos in the parts catalog, but wasn't clear about the purpose of each one, so I'll have to do some detective work as usual. I thought there would be four:
  • Driver temperature
  • Passenger temperature
  • Air direction aka mode
  • Fresh air or recirculation
Can anyone shed light on this from a 3rd gen perspective?
jonesmw10
GX - 1st Gen (2003-2009)
03-15-17 11:33 AM
Antiloop
08-26-15 10:25 AM
Dx3
SC- 1st Gen (1992-2000)
03-13-10 11:27 AM
reza
Performance & Maintenance
36
08-19-07 02:24 PM
Quick Reply: DIY: How to access blower fan servo's
