2007 lexus gs350 trunk wont open with switch
Old 04-30-17 | 11:31 PM
fahhad20's Avatar
fahhad20
Default 2007 lexus gs350 trunk wont open with switch
today i notice, 2007 lexus gs350, my trunk wont open with remote or with the switch on dash,
i can only open with the metal key from keyfob...
i chked the fuse and disconnect battery for one min , still no result. my valet switch is good too
when i close the trunk t close automatically, as it supposed to do,
is the trunk some how went to valet mode? or some thing !!!
Old 05-01-17 | 11:44 PM
ptplujo's Avatar
ptplujo
Check this thread a couple lines below yours. Sounds feasible and probable to what your having also:
https://www.clublexus.com/forums/gs-...wont-open.html
Old 05-11-17 | 10:29 AM
eggtart's Avatar
eggtart
look in your glove box there is a switch on the left side of it to lock out the trunk. Make sure the switch is OFF
Old 05-11-17 | 07:27 PM
speedkar9's Avatar
speedkar9
It could also be broken wires in the harness.
Old 06-07-17 | 11:57 AM
aneidiaz's Avatar
aneidiaz
Hey I'm having the same problem. Did you figure it out?
Old 01-13-19 | 06:02 PM
ashok9274's Avatar
ashok9274
There is Tail gate Module that is hanged up, if you take the battery out, it won't help, you need to plug in a scanner or obd II , and reset the body controller for tail gate, then the trunk will release, I hope this will help everyone, if you scan for codes, depends on the scanner ,
Old 11-23-21 | 08:47 AM
Gregoose's Avatar
Gregoose
I experienced the same issue on my 07 GS 350.
FIXED: reset the battery for 2-3 minutes which also reset the vehicle ECU. I noticed when my trunk wasn’t working during closing the hydraulic was gone. After ECU reset, it started the hydraulic motion.
jdanielca
12-05-18 02:07 PM
bgcopepod
06-01-18 08:20 PM
Z07
11-26-16 09:15 AM
shaodome
SC- 1st Gen (1992-2000)
03-30-12 08:07 AM
fxiong1
04-11-10 05:07 PM
Quick Reply: 2007 lexus gs350 trunk wont open with switch
